2 amps 2 subs Blow subs? Cap question too
Bimmerdan
Member - Posts: 6
Posted: March 04, 2004 at 5:46 PM / IP Logged
I have 2 1600 watt max amps and subs. I wanted to hook one amp up to each sub but was told that it would blow the subs in a matter of weeks is this true?
Also Any tips on on hooking up a capacitor because this will be my first time hooking one up.
Thank You
Dan
Dan Younes
1984 533i BMW
DYohn
Platinum - Posts: 10,741
Posted: March 04, 2004 at 5:52 PM / IP Logged
List the makes and models of your amps and subs.
Usmc860222
Member - Posts: 21
Posted: March 04, 2004 at 6:41 PM / IP Logged
what are the RMS of both, thats the important detail you need to pay attention to.
Bimmerdan
Member - Posts: 6
Posted: March 04, 2004 at 7:37 PM / IP Logged
The amps are (I KNOW CRAP) Legacy LA1490 RMS 100 watts, the subs are JBL 1020's RMS 400
thanks guys
Dan Younes
1984 533i BMW
Usmc860222
Member - Posts: 21
Posted: March 04, 2004 at 8:02 PM / IP Logged
so with that you wouldnt blow them, why legacy amps, they are the worst plus your running JBL's with them, its liek a great speaker and not so great amp, you should check out the JBL amps those are pretty damn good.
Bimmerdan
Member - Posts: 6
Posted: March 04, 2004 at 8:05 PM / IP Logged
Because they were all that I could afford at the momentthe JBL amps are $$$$$ Also what would running a 4 ohm amp to 2ohm speakers do just blow them?
I really wanted to get a MMATS amp but just dont have the money at the moment
Dan Younes
1984 533i BMW
Bimmerdan
Member - Posts: 6
Posted: March 04, 2004 at 8:25 PM / IP Logged
2 amps 2 subs Blow subs? Cap question too -- posted image.
2 amps 2 subs Blow subs? Cap question too -- posted image.2 amps 2 subs Blow subs? Cap question too -- posted image.MA AUDIO M683i X 800 WATT 2 CH AMPLIFIER NEW
would this be a better amp rated at 400x2RMS
Dan Younes
1984 533i BMW
Clean Install
Silver - Posts: 446
Posted: March 04, 2004 at 8:35 PM / IP Logged
? do you have the cap already ?
I am guessing from your previous post that the subs are 2 ohm are they single or dual voice coil
and your amp i assume is 4 ohm stable....or is it 2
how many amps are you going to be running????
If we learn from each success and
each failure, then we can improve ourselves
