Fuses for Coustic Power Logic Amp460?
cheagreen
Copper - Posts: 62
Posted: March 09, 2004 at 11:25 PM / IP Logged
I need fuses for my Coustic Power Logic amp460. Its 250 wrms. What size fuse for the amp? It has two slots for fuses. What size fuse? Thanks guys
Head Unit:Pioneer-Deh-1600
Fronts:Kicker 6x8 S57's
Front Amp:Coustic PowerLogic Amp460
Rear Fill:Stock 6x8's
Subs: 2 10" JL Audio W3's
Sub Amp: JBL bp600.1
Wiring: KnuKonceptz
RalphWiggum
Member - Posts: 34
Posted: March 10, 2004 at 10:57 AM / IP Logged
Coustic lists the amp as having only (1) fuse rated at 40amps for that amp.
http://www.coustic.com/classic/PDFs/U-SERIES.PDF
Fuses for Coustic Power Logic Amp460? -- posted image.
markcars
Silver - Posts: 662
Posted: March 10, 2004 at 11:02 AM / IP Logged
Did your amp not come with a fuse? They normally come with fuses as part of the amp. If the fuse blows, then you'll have to get new fuses but the holders are there already I think.
cheagreen
Copper - Posts: 62
Posted: March 10, 2004 at 11:52 AM / IP Logged
Yea, at that website coustic doesn't list my amp in the classic section. The one thats in their isn't my amp. My amp has two slots. I've already checked that site out and it's a bummer.
This amp was givin to me WITHOUT fuses.
Wiring: KnuKonceptz
forbidden
Platinum - Posts: 5,354
Posted: March 10, 2004 at 2:19 PM / IP Logged
Confirm the power rating of the amp for the number of channels driven. Is this a 4 channel amp?
markcars
Silver - Posts: 662
Posted: March 10, 2004 at 7:14 PM / IP Logged
if you check this site, it gives you how you can calculate how much amp fuse you need once you know the channels you have and the power either RMS or PMPO.
http://www.gohoautoaudio.com/html/amp_power.htm
check it. you should be able to find the amperage of the fuse.
superstreet786
Silver - Posts: 339
Posted: March 10, 2004 at 8:55 PM / IP Logged
damn most amps will tell u on the amp right by the slots what fuses to use
---- 1996 Chevy S10 ----
1 Lightning Audio S2.600.2 Amp
2 Lightning Audio 12" Subs
1 Lightning Audio 1 Farad Cap
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
