question about a amp
kyle550
Posted: March 10, 2004 at 1:01 AM / IP Logged
Is there any way to hook up a mono channel amp to, 2 single coil subs??
cheagreen
Copper - Posts: 62
Posted: March 10, 2004 at 1:19 AM / IP Logged
Their sure is. How many  ohms stable is your amp, and how many ohms are your subs? DETAILS PEOPLE lol.
Head Unit:Pioneer-Deh-1600
Fronts:Kicker 6x8 S57's
Front Amp:Coustic PowerLogic Amp460
Rear Fill:Stock 6x8's
Subs: 2 10" JL Audio W3's
Sub Amp: JBL bp600.1
Wiring: KnuKonceptz
kyle550
Posted: March 10, 2004 at 8:54 AM / IP Logged
I have a rockford 301m, it is 900 Watts Peak/Max 150 Watts RMS(it says this online, but at home it says it is 300 watts RMS??), 150 x 1 @ 4 ohms, 300x1 @ 2 ohms.  My subs are 2 10" Pioneers.  They are TS-W29C they have a ohm rating of 4.  Im not at home right now so I can't look at the box so I am getting all the info online.  Here are the subs I have http://www.pioneerelectronics.com/pna/product/detail/0,,2076_4059_38285_tab=B,00.html?compName=PNA_ProductDetailComponent
And this is the amp http://www.rockfordfosgate.com/ez2/ModelInfo/ModelInfo.asp?ItemKey=10061221&CategoryDesc=Punch%20Amplifiers
Thanks for the help, as you can tell I am new at this....
Spaceman Spiff
Member - Posts: 28
Posted: March 10, 2004 at 12:07 PM / IP Logged
You CAN run both of those subs off that amp. You will wire the speakers in parallel which will give you a 2Ohm load on the amp.
kyle550
Posted: March 10, 2004 at 1:47 PM / IP Logged
Is there a reason why CAN is in all caps? I had them run in parallel already, but I blew one sub.  I took it to Best Buy and they said that the amp couldn't handle the way I had it set up....If someone could answer why that happened thanks...
forbidden
Platinum - Posts: 5,354
Posted: March 10, 2004 at 2:39 PM / IP Logged
Turn around and run away, hurry Best Buy man is catching you. You have a mono sub amp that is designed and engineered to operate at a 2 ohm mono load, thus two 4 ohm subwoofers wired in parallel will indeed work with your amp. Here is the way it should have been wired for you, double check the wiring.
Wiring Option #1
question about a amp -- posted image.
If you blew a sub, chances are that the gain on the amp was too high, or a bass boost was too high. A sub does not blow on it's own. Chances are that your other sub is not far behind.  A su blows when the voice coils cannot cool down, be it from excessive and consistent volume levels, running the amp out of clean power (clipping) - this causes the amp to produce a distorted signal that the speaker will reproduce until it fails. It takes time to blow a sub, it generally does not happen right away. Best Buy guy could not have been any further away from the truth. If you need more info please post it up.
Teken
Gold - Posts: 1,492
Posted: March 10, 2004 at 4:35 PM / IP Logged
LMFAO !!! question about a amp -- posted image. They do sell good dish washers there, though.
Regards
EVIL Teken . . .
kyle550
Posted: March 11, 2004 at 11:37 PM / IP Logged
Hey thanks for the help, I will try it out this weekend, hopefully everything works fine.  I do have the warranty so I can just get a new sub if I accidently mess it up...lol.
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
