fuse amps for fuse holder
fifibone48
Posted: March 10, 2004 at 11:32 AM / IP Logged
Hello, I have an Audiobahn amp that has 3 30 amp fuses in the back of the amp.  The only question I have is what amp fuse should i use for the fuse holder located near the battery.  Do I add the total amps of the ampifire which would be 90 amps so does that mean that I should have an amp fuse up to 90 amps in the fuse holder?
lagatbezan
Copper - Posts: 117
Posted: March 10, 2004 at 4:44 PM / IP Logged
u always want to put a fuse slightly smaller then the ones in the amps.  I would recomend a 70 or an 80.
customsuburb
Gold - Posts: 1,813
Posted: March 10, 2004 at 5:44 PM / IP Logged
Use a 100 amp fuse or a similar sized circuit breaker.
Usmc860222
Member - Posts: 21
Posted: March 10, 2004 at 9:25 PM / IP Logged
you dont use a circuit breaker, if you do that you might fry your sh*t if too many amps are going through it
fifibone48
Posted: March 11, 2004 at 1:16 AM / IP Logged
Yeah, thats what I thought, will use an 80 amps fuse for the fuse holder just to keep my Audiobahn amp out of trouble.  Would hate to fry the Audiobahn amp.  Thanks
Tuesday, April 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
