Dual Voice Coil Subwoofer Question
pspadotto
Member - Posts: 19
Posted: March 22, 2004 at 12:47 AM / IP Logged
I was hoping someone might be able to help me out with this question:
I'm setting up my ford focus with a 2 ohm DVC subwoofer.  I have a 2 channel amplifier that runs:
200 watts RMS x2 channels @ 4 ohms
300 watts RMS x2 channels @ 2 ohms
400 watts RMS x1 channel (bridged) @ 4 ohms.
Now, I read on crutchfield that a DVC subwoofer can have an individual channel from an amp connected to each coil, rather than a bridged single channel.  If this is true, and I connect each of my 300 watt channels (@ 2 ohms each) to a separate voice coil, will the output on the subwoofer be combined to 600 watts?  If so, I'd much rather do that than settle for the 400 watts at 4 ohms bridged.
-Pete
thapimpfromchi
Silver - Posts: 616
Posted: March 22, 2004 at 2:38 AM / IP Logged
Yea it's true. You can wire each VC to a seperate amp, but I wouldnt recommend it. It's alot harder than it sounds. you have to get crossovers (i think) to make sure each amp gets the exact sam signal, and puts out the same signal. If they arent operating in sync, bye bye woofer. But, since you are willing to get another amp, why dont  you just go out and buy an amp that has some more power, and wire both VC's to one amp?
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
pspadotto
Member - Posts: 19
Posted: March 22, 2004 at 8:06 AM / IP Logged
Actually, I was more thinking that I would wire each channel from my existing 2 channel amp to a separate voice coil...is that possible?  And what would the wattage work out to, given the RMS listed above?
DYohn
Platinum - Posts: 10,741
Posted: March 22, 2004 at 8:22 AM / IP Logged
If you wire each 2-ohm VC to its own channel, with the amp specs you list you would deliver 300 watts to each VC.  The trick to making this work without tearing your sub apart is to make sure you are sending the exact same signal to each channel of the amp.  If your HU has a mono sub output, use a Y-cable and split it to each channel.  DO NOT run a stereo signal to the amp.
pspadotto
Member - Posts: 19
Posted: March 22, 2004 at 11:52 AM / IP Logged
That makes a lot of sense, and it was along the lines that I was thinking.  Now, with 300 watts going to each voice coil, what is the total wattage being put out by the sub, 300 or 600?  Thanks again!
DYohn
Posted: March 22, 2004 at 1:18 PM / IP Logged
The total wattage being CONSUMED by the sub will be 600 watts at full volume, assuming the amp ratuings are correct.  The power OUTPUT will be measured in decibels.
forbidden
Platinum - Posts: 5,354
Posted: March 22, 2004 at 1:42 PM / IP Logged
I would disagree with the amps listed power rating, usually the 4 ohm bridged mono rating is equal to or slightly more than the 2 ohm stereo load. What amp is this that you have, let's double check it's "specs". Post the sub for us as well please.
thapimpfromchi
Silver - Posts: 616
Posted: March 22, 2004 at 2:24 PM / IP Logged
hey man, using the mono wire and using a y splitter, wouldnt he have to reverse the signal to one vc? I had set up 2 SVC subs, with a single rca and a Y splitter, but it sounded horrible. i reversed the one speaker and it was great.
pspadotto
Member - Posts: 19
Posted: March 22, 2004 at 2:29 PM / IP Logged
The Amp is a Visonik V217SX.  I can't for the life of me remember the model number of the sub right now.  I'll post it after I get home from work.
DYohn
Posted: March 22, 2004 at 2:38 PM / IP Logged
That amp is actually more like 2 X 150 or maybe 200 watts into 2 ohms.  It may say "800 watts" on it, but that is a load of, err, buffalo flush.
