Solo x and PPI
flatulatta
Silver - Posts: 356
Posted: April 02, 2004 at 9:30 AM / IP Logged
ok my friend has a PPI PCX1500 its rated at 1000w rms @ 2 ohms but it pushes way more my question is will this amp supply enough power to push a solo x 18 or possibly a 12 or 10?? thanks
DYohn
Moderator - Posts: 10,741
Posted: April 02, 2004 at 11:27 AM / IP Logged
The PCX1500.1 is a decent amp and the 1000 watt rating is a TRUE 1Kw.  Sure, this will "push" a Solo X, but not anywhere near its lmits.  If you are really ready to spend over $1000 on a pure SPL 100lb woofer like a Solo X, then spend the money on the right amp for it as well in my opinion.  If you're looking for that hard-kore competition-level SPL that the Solo X can produce (and forget about anything that even resembles SQ) match it with a competition-level amp like an Orion 2500D or a SOundstream 5000D.
flatulatta
Silver - Posts: 356
Posted: April 03, 2004 at 9:17 AM / IP Logged
well my friend wants to run 1 solo X and his 2 current L7s
so... 2 l7s off of his pcx1500 and then and orion for the solox???
DYohn
Posted: April 03, 2004 at 9:21 AM / IP Logged
That would work.  In fact, that way you could keep the Solo X beast turned off unless you are competing.  Trust me when I say it is NOT a speaker you will want to listen to every day...  :)
Teamrf
Gold - Posts: 1,031
Posted: April 03, 2004 at 9:37 PM / IP Logged
You must don't like hearing anything around you
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
netboy
Copper - Posts: 108
Posted: April 04, 2004 at 3:13 AM / IP Logged
Dude, that is going to be LOUD
Memphis MC-1300
2 12" JLw6v2
Diamond audio M3 6x9
Diamond audio M3 5.25 components
Audio control Matrix
Carputer
BangBang
Silver - Posts: 287
Posted: April 04, 2004 at 12:13 PM / IP Logged
ok wut would u suggest
the ppi pcx1500 or the 801s fosgate?
BangBang
Silver - Posts: 287
Posted: April 04, 2004 at 12:19 PM / IP Logged
forbidden
Platinum - Posts: 5,354
Posted: April 04, 2004 at 5:11 PM / IP Logged
Whats' that I can't hear you over the bass!
DYohn
Posted: April 04, 2004 at 6:06 PM / IP Logged
That link is to an auction for one of the best car audio amplifiers ever built, bar none.  Absolute top of the line.  The description is not an exaggeration.  Check Loren's other auctions for the matching head unit.  This is the system I would put in my car if I was building another system (and had the friggin' ROOM for it!)
Thursday, October 23, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
