OEM Head Unit Accord Euro 04
s2k_2k1
Posted: April 04, 2004 at 8:01 PM / IP Logged
how do i pull the OEM headunit on the new accord euro 04 ?
thank you OEM Head Unit Accord Euro 04 -- posted image.
Chad7n7
Silver - Posts: 408
Posted: April 05, 2004 at 2:31 AM / IP Logged
GOOD LUCK!!!!!!  These are very much a pain to deal with, but here goes!! The molding piece around the shift snaps on and off. Remove that, there are two screws under there you have to remove, pull the little console in front of the shift out, there are two screws under the HU that you access there, the air conditioner vents on top of the unit, push them up and look in the top there is one screw in each. Now the molding around the HU should pop off, and from there you should have access to the HU to pull it out.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
