2004 Toyota 4Runner Limited
nava94
Silver - Posts: 296
Posted: April 08, 2004 at 12:18 AM / IP Logged
Hey guyz need some help on getting the diagram for the factory radio plug on a 2004 Toyota 4Runner Limited with JBL Synthesis System.No Aftermarket plug is available yet to install an aftermaket radio.
jfk51502003
Copper - Posts: 221
Posted: April 08, 2004 at 4:31 PM / IP Logged
l
Radio 12v blue / YELLOW  +  radio harness
Radio Ground brown  -  radio harness
Radio Ignition gray  +  radio harness
Radio Illumination green  +  radio harness
Factory Amp Turn-on
Notes: If equipped, the stereo amplifier is behind the passenger side quarter panel.
Power Antenna black  +  radio harness
LF Speaker +/- pink - purple  +,- radio harness
RF Speaker +/- lt. green - blue  +,- radio harness
LR Speaker +/- black - yellow  +,- radio harness
RR Speaker +/- red - white  +,- radio harness
2004 Toyota 4Runner Limited -- posted image.
Immobilizer Bypass Module:Required: YesType: TransponderPart #: 555U
Notes: N/A
hope this helps...
nava94
Silver - Posts: 296
Posted: April 08, 2004 at 8:57 PM / IP Logged
The 4Runner has has 2 front speakers w/tweeters, center speaker, 2 rear door speakers, and a sub w/2 rear tweeters in the d-pillar. do you have the diagram for that or the diagram for the factory amp.
lagatbezan
Copper - Posts: 117
Posted: April 08, 2004 at 9:44 PM / IP Logged
actually i believe bast kits does make a harness for this car: part number:
BHA8113
here is the link:
http://bestkits.com/Search.aspx
