What amp for 12w7, JL or Alpine?
crudeau
Copper - Posts: 150
Posted: April 14, 2004 at 9:15 AM / IP Logged
I already own a 12" w7 that I just built a new box for.  A slot ported box.  In my old setup I had the w7 in a sealed enclosure, with a JBL BP1200.1 running it.
The thing sucked.  THe JBL didn't like the 3 ohm load and it soundlike I had a walmart 8 inch free air sub in the car.   My local shop is lending me an Alpine V12 MRD-M1000 to test it with this weekend.  It's $550 if I decided to buy it (new).
I am just wondering what amps everyone uses to power w7's,   I don't want the JL amps because they are like $200 more then the alpine.
DYohn
Platinum - Posts: 10,741
Posted: April 14, 2004 at 9:47 AM / IP Logged
There is no reason the JBL amp would not do the job, if you had it set up correctly and had the sub in a properly designed enclosure.  If it "sucked" I suspect it was not set up correctly.  JBL amps are stable to a 1-ohm load and they are very happy at 3-ohms.  The Alpine amp is a fine amplifier.  EITHER will do about the same job with your W7.
crudeau
Copper - Posts: 150
Posted: April 14, 2004 at 10:14 AM / IP Logged
THe JBL amp has always worked fine for me.  and it loves 1 ohms.  But it did not like the 3 ohm load whatsoever for me.  It did sound good.  but it was hitting like an 8 inch sub.  I tried the amp on two 15 w3's and it hit them hard as hell.  I did that to test if it had finally went south on me.  Well I have the new box and it's going in this weekend.  So I will give the jbl a second chance. but I think I like the way this alpine looks 20 times better.  and it's easier to do a clean install with it.
Alpine Guy
Platinum - Posts: 2,478
Posted: April 14, 2004 at 8:36 PM / IP Logged
if you think the mrd-m1000 looks nice, , then take a gander at the new mrd-m1001.
customsuburb
Gold - Posts: 1,813
Posted: April 14, 2004 at 8:39 PM / IP Logged
The day when an amp's looks make it sound better will be when volfenhag will equal eclipse. What amp for 12w7, JL or Alpine? -- posted image.
Alpine Guy
Posted: April 14, 2004 at 9:17 PM / IP Logged
lol
djdaveoc
Copper - Posts: 231
Posted: June 14, 2004 at 10:24 PM / IP Logged
I just bought a PPI PCX-1500 to power the 12W7 I'm going to buy soon.  I guess it puts out about 750 watts RMS which is what the sub is supposed to have powering it if you look at the JL Audio chart.
What amp for 12w7, JL or Alpine? -- posted image. Plan, Research, Do
Thursday, March 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
