2 10'' subs, 4 ch or 2 ch amp?
Beerman354
Member - Posts: 19
Posted: April 14, 2004 at 3:53 PM / IP Logged
I am getting 2 10" sub with 500watt rms power handling. Should i get a 4ch which is 80x4 amp and bridge it to like 320x2 Or a two channel amp bridged to 1 ch and split the wattage???
kickerstang
Copper - Posts: 180
Posted: April 14, 2004 at 3:57 PM / IP Logged
it depends if the subs are single coil or dvc and also depends on what kind of ohm load the amps can handle.  specify the type of subs and types of amps so we can give you a better answer
what!?!?! you want some??
Beerman354
Member - Posts: 19
Posted: April 14, 2004 at 4:00 PM / IP Logged
The subs are polk momo mm104s and are 4 ohms the 4 ch amp is a ppi pcx480... I dont really know of ne good 2 ch amps.
Beerman354
Member - Posts: 19
Posted: April 14, 2004 at 4:01 PM / IP Logged
Oh yeah they are single voice coil
bfog99
Copper - Posts: 212
Posted: April 14, 2004 at 6:33 PM / IP Logged
another amp suggestion is the jbl bp600.1. can get it retail for about 300 and online for about 200. run the subs in parallel for a 2 ohm load and it will push 300 watts to each sub.
aggie altima
Silver - Posts: 298
Posted: April 14, 2004 at 6:41 PM / IP Logged
i would try to get a class D amp. No need to have subs in stereo, so a mono amp would be just as good, and class D is more efficient than class A/B. That jbl amp would be a good inexpensive choice.
Jon
Don't like rockford subs? Then don't look at my car =)
Beerman354
Member - Posts: 19
Posted: April 14, 2004 at 7:01 PM / IP Logged
     Thanks for the replies.What are some good class d amps.... Price is not really an issue.
bfog99
Copper - Posts: 212
Posted: April 14, 2004 at 7:15 PM / IP Logged
to name a few...
jl audio 1000/1
jbl bp 600.1 or 1200.1
alpine mrdm1000
rockford fosgate 1001db
customsuburb
Gold - Posts: 1,813
Posted: April 14, 2004 at 7:59 PM / IP Logged
Zapco, PPI, Planet Audio....
forbidden
Platinum - Posts: 5,354
Posted: April 14, 2004 at 8:05 PM / IP Logged
Eclipse, Concept, Lightning.....
