Posted: May 02, 2004 at 9:42 AM / IP Logged
Posted: May 02, 2004 at 9:59 AM / IP Logged
Posted: May 02, 2004 at 10:58 AM / IP Logged
Posted: May 02, 2004 at 11:06 AM / IP Logged
Posted: May 02, 2004 at 11:39 AM / IP Logged
Posted: May 02, 2004 at 2:41 PM / IP Logged
Posted: May 02, 2004 at 2:47 PM / IP Logged
Monday, March 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
. I would choose a dvc 4 ohm sub and wire it up in series. This will make it an 8 ohm sub and knock the amps power back to something reasonable so that you can actually listen to the music. The JL is a good sub, personally I would head in the direction of one Eclipse Aluminum SW8102dvc and build the proper 1.25 cu.ft sealed enclosure for it and play away to your hearts content. I think the Titanium model that Dyohn mentioned is an awesome sub, but is probably a little more than you would require.
