speaker hookup
clovis
Member - Posts: 7
Posted: May 11, 2004 at 4:36 PM / IP Logged
I am installing two pair of Alpine speakers into my boat (wakeboard tower).
The speakers are SPS-170A and SPR-174A.  I am running them on an old Sony XM-3040F.  My question do I bridge the amp and run each pair at 8 ohms or just run each one on a separate channel.  My speakers cans hold a pair.
I would like to run as few wires as possible up the tower, but I obviously I want to get as much to the speakers as possible.  The amp is suppose to run 30rms @ 4, and 40 @ 2.  The speakers are not power mongers, they are recommended for 40 rms, part of the reason I bought them.
Although the SPR's have their own crossover, I am also using an XM-3 Coustic crossover to filter out some of the base, what is a good crossover point for both speakers since the crossover has to be the same for both (one of each in the cans).
thapimpfromchi
Silver - Posts: 616
Posted: May 11, 2004 at 6:03 PM / IP Logged
i'd wire them at 4 ohms. each one to a channel. More power to each. As for the x-over, depends on how much bass you want to take out of your music.
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
clovis
Member - Posts: 7
Posted: May 12, 2004 at 8:25 AM / IP Logged
Most of my music doesn't contain a big bass element, but  I am also installing a small JBL GT650T sub with its own amp (Pioneer GM-X252) so it will have around 100rms.  I just figured the more bass I cut, the more power I can focus on a clean higher freq signal, which is where my music is.  I have read that most of the power is used under 300, so that is about where I had thought about cutting it.
I have three outputs on the crossover and headunit (frt, rear, sub).  I had thought about crossing the 170's (non-component) at around 1k, then crossing the 174's at around 100-150, since they have an external crossover they can handle the bass better than the co-axial 170's.  The only problem is that I lose my ability to fade front to rear (tower to the interior) because I would have the tower running on both front and rear channels from the headunit.
Sunday, July 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
