i need help installing amp
00neon
Copper - Posts: 61
Posted: May 18, 2004 at 8:54 PM / IP Logged
first i hope this is in the right fourm
ok tonite i dont know what i was thinking, i must of had my head up my butt..........anyway, my brother and i were trying to intall his wiring kit for his amp. the previous owners of his car, did not care for it and bought the wrong group battery for it, this put the terminals in the front of the battery. so in my all non-exsistent brillance tonite i decided to turn the battery around. TOTTALY forgetting that the terminals moved also, so i put the positive on the neg terminal, and then try to put the neg on.....horn honks, think nothing of it, try again, horn honks, then i look........blew the fuse for the raido (fixed), blew the circuit breaker for the power windows (fixed)......and the one that has me all sorts of confused, the wipers will start going with the key in any "on" postion, acc, etc.....................fuse is fine, motor must obviously be fine..............couldnt find a fuse under the hood............anyone have any help?????????????
1 JL 12 w3 D4
1 MTX 421 D Monoblock
1 Sony Xplod 75x4
Front: Alpine SPX-177A
Rear: JL audio VR690-CXI
Type S
Member - Posts: 15
Posted: May 18, 2004 at 9:35 PM / IP Logged
The kind of car would really help!
If something is not working as planed, Check your ground i need help installing amp -- posted image.
stevdart
Platinum - Posts: 5,816
Posted: May 18, 2004 at 9:45 PM / IP Logged
You will most likely find more wrong than the wiper motor relay.  Parking brake cable still intact?  The current was sent through the chassis, so any wires or cables in the car might be fried.
DYohn
Platinum - Posts: 10,741
Posted: May 18, 2004 at 9:54 PM / IP Logged
Yea, I call that kind of mistake the BIG oops.  Time for a tow to the shop and you'd best have a fat wallet...
00neon
Copper - Posts: 61
Posted: May 18, 2004 at 10:43 PM / IP Logged
aight its a 2000 neon..............the car runs fine, just the wipers is the only thing screwed up right now
1 JL 12 w3 D4
1 Sony Xplod 75x4
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
