rough figure for db's of my setup
shane7643701
Copper - Posts: 41
Posted: May 23, 2004 at 8:19 AM / IP Logged
I have a 94 gmc sierra ext. cab and I am thinking of running 4- 10 inch MTX 8000's single voice coils wired in a 2 ohm load and pushed by kicker kx800.2 amp, was wandering of about or any idea of the db's that might come out of this?
live in your world, come play in mine
Alpine Guy
Platinum - Posts: 2,478
Posted: May 23, 2004 at 10:21 AM / IP Logged
any where from 0-135 would be a rough figurerough figure for db's of my setup -- posted image.    Its impossible to give you a close estimate.
DYohn
Moderator - Posts: 10,741
Posted: May 23, 2004 at 11:38 AM / IP Logged
Ditto to the "impossible to tell" comment from Alpine Guy.  But before you hook up your system and start trying to hit ANY db number, realize a couple of things: That Kicker amp cannot be bridged into a single 2-ohm load.  It is only capable of sustaining a 4-ohm load when bridged.  Also, the SVC MTX 8000 series is a 4-ohm speaker, so you cannot connect 4 of them togehter to achieve a 2-ohm net load.
customsuburb
Gold - Posts: 1,813
Posted: May 23, 2004 at 12:43 PM / IP Logged
Wire your MTX 8000s like this:
haemphyst
Platinum - Posts: 5,059
Posted: May 23, 2004 at 10:33 PM / IP Logged
Actually, guys, it IS possible to tell a rough estimate of how loud he will get.
1: Take the efficiency specification of the driver in dB/1w/1m. Call that number X
2: Add 6 (because there are 4 drivers) X+6=Y
3: Starting with 4 (1 watt per driver) count how many steps it takes to get to 400 (which AFAICT is the 4 ohm bridged power of this amp) Call that number N
4: Take that number, multiply by 3 N*3=Z
5: Add that number (Z) to Y
Example:
X=90
X+6=Y=96
4,8,16,32,64,128,256 (The remaining 128 watts available from the amp will add about 1.5 dB) 7 doublings * 3dB per doubling = Z = 21dB additional output.
96+21=117 dB, give or take a couple.
Alpine Guy, you ARE correct, it IS between 0 and 135dB, but I think shane7643701 was looking for something a little closer... I just wanted to show that it is possible, given at a minimum, the number of drivers, the amplifier power, and the efficiency of the driver, you CAN indeed get an estimate of the system output. I do want to mention, though, these ARE anechoic numbers, and the cabin gain (and cabin gain IS dependent on the cabin, obviously) can add as much as 12dB at various frequencies, but NOT across the board.
auex
Platinum - Posts: 5,041
Posted: May 23, 2004 at 11:16 PM / IP Logged
Ok, here is the problem with your formula. First, it is correct for home audio where you are dealing with sound waves, but in cars you deal with sound pressure (notice why soundoffs are called SPL not DBL), but since you know the formulas you should know this already. Out in the open or in a warehouse these formulas would probably work rather well to get an estimate. Also, we have no idea what kind of box he has the subs in, which will affect the sensitivity of the sub greatly (remember that sensitivity is done in a warehouse, free air, with a mic that is 1 meter away with 1 watt of power). The sensitivity of the sub is a rather useless number unless you are going for sq+. This is just my 2 cents from experience.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
haemphyst
Posted: May 24, 2004 at 12:30 AM / IP Logged
ALL SPEAKERS MAKE SOUND WAVES. Sound in measured in SPL WHEREVER you measure it. Yes you DO deal with sound pressure, but in the home (or warehouse or wherever) you also deal with sound pressure, WHEN THE WAVELENGTH IS LONGER THAN THE ROOM... it is still sound! (I think you are getting confused between sound and sound pressure... they ARE the same thing) The same rule applies in the car, this is called room (or, in the car, CABIN gain). The numbers above, are (yes, I admit, I should have specified the TYPE of enclosure) for a sealed enclosure. Add 3 dB for a vented enclosure, or 6dB for a bandpass enclosure, but also remember that when you vent a small (required for automotive use, because of the physical limitations of the CAR) you will sacrifice low frequency extension for output. Ya canno' change the laws o' physics! You will also notice that I did refer to cabin gain, and I also mentioned that cabin gain is not a uniform boost across the spectrum. It will be based on the HARMONICS of the cabin. Smaller cabins, such as trucks, will enhance higher frequencies, and larger cabins, such as an Explorer or the like, will enhance lower frequencies. Also, most manufacturers base their sensitivity ratings on the Theil-Small parameters of the driver (mathematically derived, based on MMS, BL, and other parameters that are relatively fixed values), they do not put the driver in a box, and test it - they can't, because of the tens of thousands of drivers they make, and I can tell you this is true, because I have measured literally hundreds of drivers, and VERY few ended up being right on the mfr. spec. for efficiency. It actually comes closer to an infinite baffle sensitivity, also. The spec will change, based on the tolerances allowed in the manufacturing process, usually + or - 10 percent. More expensive drivers will usually use higher tolerance parts, and therefore come closer to mfr spec.
I really am curious, what makes you believe that a woofer does something different in an automotive environment than in a home environment? All loudspeakers, from tweeters to woofers, to full range drivers, are electromechanical devices that do nothing more than excite air molecules in a compression/rarifaction pattern, based on the frequency being reproduced. It does not matter where it is measured, as long as you allow for room gain. You will get the output of the driver. The space (distance) between the wave (the outward movement of the cone - high pressure) and the trough (the inward movement of the cone - low pressure) is called the wavelength, and it is the same in a car as it is in a non-moving rigidly placed building. The room (or cabin - interchangeable, both verbally and physically) has an effect on SOME of the frequencies more than it does on others. These are called standing waves, and you can figure these as well, AND say how much the gain will be at a given frequency, as well as the harmonics of that peak frequency, with relative precision.
haemphyst
Posted: May 24, 2004 at 12:43 AM / IP Logged
Oh, and efficiency has NOTHING to do with whether a driver will be an SQ driver or a high output (I do not want to say SPL) driver in a perticular application. I have seen extremely inefficient driver simply BLAST with enough power, and I have seen very efficient drivers sound simply PHENOMENAL. I have also seen extremely inefficient drivers sound like CRAP, and very efficient drivers not play as loud as one would expect, because they cannot handle any power to speak of. Play around with Tractrix horns and transmission-line enclosures, before you say something like "efficiency is a useless number except for SQ drivers"...
Sorry for the tone... sometimes I get a little passionate about my audio, AND my actual schooling in the audio world, as well as my years of hands-on experience. I admit I do not know everything, but I am quite knowledgeable in what I do know, and I am always looking to learn more.
I do know that if Steven Kephart is reading any of these posts, he will correct me, and I hope that he does.
chevyman26
Copper - Posts: 227
Posted: May 24, 2004 at 1:17 AM / IP Logged
 This may have just been covered in the above posts, but I have done some tests with woofer location in the vehicle (only 1 vehicle, actually- a 1994 Buick Regal. A pretty avererage sized car) and we found that if using two woofers in seperate boxes, placing them at the rear of the trunk w/ 1 on each side behind the tire wells gave us the highest output on the db meter (I know there's a proper name for it but it escapes me right now). Even having two subs in one box, measuring with the box all the way towards the back of the car yeilded  1.2 db higher than when the box was pushed all the way towards the front of the car (but still in the trunk.)  This is supposed to be because of the way the sound waves bounce off of the solid panels of the car and the distance they must travel before they get to your ear (or the mic.) Someone else will be better at explaining the specifics of this theory.   I am currently using a q logic box under the driver side rear set of my 97 ext cab chev. I have tried having the box in every nook and crannie in every possible position, and have found that spot to be the best. Obviously when using 4 subs you have a lot less options as to placement.
So anyways- If this is what haemphyst was referring to as "cabin gain", then I just typed my fingers raw for nothing. If this is not "cabin gain", haemphyst, could you please elaborate on what it actually is? I too like to continually learn at every chance I get.
Thanks, and hope my $.02 helps.
You'd better get me out of this lord... or else you'll have me to deal with. -- Hunter S. Thompson "F.A.L.I.L.V."
haemphyst
Posted: May 24, 2004 at 8:42 AM / IP Logged
cabin gain...
Friday, November 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
