lost slot port formulas
italnpimp59
Silver - Posts: 427
Posted: May 30, 2004 at 12:34 AM / IP Logged
i used to have all the formulas for calculating and tuning slot-ported boxes in programs i made for my graphing calculator, well i lost the calculator and cant find the formulas anywhere.   if someone would give them to me i would really appreciate it.  i need the tuning frequency, peak frequency, and the 3db rolloff frequency.  and the dB at any given frequency so i can make a graph and see what kind of sound this box will produce at all frequencies.  thanks in advance!!
DYohn
Moderator - Posts: 10,741
Posted: May 30, 2004 at 11:39 AM / IP Logged
italnpimp59
Silver - Posts: 427
Posted: May 30, 2004 at 7:44 PM / IP Logged
that only has the formula for tuning frequency, do you know where i can get the others?  thanks for that one though!
bdl666
Silver - Posts: 330
Posted: May 31, 2004 at 3:38 AM / IP Logged
 I can't find my books now, but I'll keep looking for them. In  the mean time try this program out.
http://www.linearteam.dk/default.aspx?pageid=winisdpro
It does what you need and more. It even has a signal generator and it can plot graphs for spl, impedance, impedance phase, group delay, maximum xpl, maximum power, and a lot more. Plus it's free.
italnpimp59
Silver - Posts: 427
Posted: May 31, 2004 at 1:10 PM / IP Logged
wow that program is awesome, thanks alot for your help man!!!lost slot port formulas -- posted image.
italnpimp59
Silver - Posts: 427
Posted: May 31, 2004 at 1:36 PM / IP Logged
oh one question about that program, is there a way to input my own dimensions for slot ports and it can figure out the length it needs to be?  it has defaulf 1.85,2.86,3.23,4.02,5.51 for length and width and i have to choose.  i want to build a box with suppose two 2 inch by 15 inch slot ports and i want it to find out the length, is there a way to do that?
sandt38
Copper - Posts: 60
Posted: May 31, 2004 at 4:55 PM / IP Logged
Sure, just override the default value and add your own value. Select your desired port tune and it will calculate the port length. Also of note, it has a vent mack calculator to let you know if you will suffer port noise.
Be sure the parameters are in the correct english/metric format as well.
ISD is a great freeware. Not perfect, but really easy and really close.
