Alpine CDM-9821 Preout?
1 Lt.
Posted: May 30, 2004 at 9:51 PM / IP Logged
Im new at this but I think I have everything figured out. My only question is can I use this 'preout' on my HU to send the signal to my amp, powering the woofers, and then just use crossovers to gather the correct signal? I only ask because according to Alpine my HU, CDM-9821 can do only one of two things. The first is to power front and rear speakers, the second option is powering front speakers and subwoofers.
So with this preout can I power front and rear speakers and the subs?
boomer_106
Silver - Posts: 710
Posted: May 30, 2004 at 10:08 PM / IP Logged
sure the preamp output will plug into your amp. Hopefully your amp or amps has a built in crossover.
Alpine Guy
Platinum - Posts: 2,478
Posted: May 30, 2004 at 10:11 PM / IP Logged
Just be shure to turn the subwoofer setting in your deck off.  then it will send full range signals, just now you can't use the sub boost and cut feature.
Manoftools
Copper - Posts: 55
Posted: May 30, 2004 at 10:14 PM / IP Logged
I dont understand your question about crossovers... but the only way that you can use that preout and amp subs and a 4 channel is by using splitters and splitting it.  I wouldnt recommend splitting out preout to six different channels.  So, use it for your subs and if you want to add a four channel I would get a radio with more preouts.
djMINIoompa
Copper - Posts: 125
Posted: May 31, 2004 at 11:33 AM / IP Logged
Really?
1 Lt.
Posted: May 31, 2004 at 3:07 PM / IP Logged
So just to make sure I understand everybody. I can use the preout to send the signal to the woofers and plug my other speakers into the regular outs? Correct?
forbidden
Platinum - Posts: 5,354
Posted: May 31, 2004 at 3:15 PM / IP Logged
Post up exactly what you have for equipment and how you want to wire it please.
1 Lt.
Posted: May 31, 2004 at 3:21 PM / IP Logged
My HU is an Alpine CDM-9821, my subs are two JL w0's powered by a JL monoblock 200w amp, I have two 3.5" Xplode XS-W3521 and down the road I want to install two 6x9" speakers for the rear. My problem is that according to Alpine my HU can only do one of two things. One is power the front speakers and subwoofers or power front and rear speakers. I want to power front, rear and send the signal to my sub amp.
customsuburb
Gold - Posts: 1,813
Posted: May 31, 2004 at 3:31 PM / IP Logged
I own this deck. It only has one set of preamp outputs. So, if you had a 4 channel amp for your front and rear speakers and an amp for your sub you will need an external crossover. I know Audio Control and Crossfire make some nice ones. Try the Audio Control 2XS. The only problem with your deck is that you wont be able to fade between the front and rear speakers using its controls. I would personally just use an amp for your subs and power the interior speakers (at least for right now) off of the deck's internal amp (unless you have a good external amp that you really want to use).
Alpine Guy
Posted: May 31, 2004 at 3:45 PM / IP Logged
What they mean by that, is you can only do that if only using the rca outputs.  But you are still allowed to use the 4 channel internal amp, plus you can use the RCA output to send signals to your amp  power your subs.
So use the wires in the wire harness to power your speakers, , and then plug in some rca's to the back of the deck and connect it to your amp.  Just be shure to turn on your "subwoofer" in the set up of the deck.
