need help soldering!
harvey1959
Copper - Posts: 94
Posted: June 03, 2004 at 10:00 PM / IP Logged
I know that twisting wires is not the best  way to make connections, but I don't solder too good.  I make my connections by doing a twist, then looping that twist around itself and giving it a few good tugs before I wrap it.  I haven't had a problem yet, but I would like to learn to solder.  Is it like soldering copper pipe,  clean it, flux it, heat the joint and then touch the solder to the joint and let the solder suck into the joint.  Also what type of solder do you use?
Harv
DYohn
Platinum - Posts: 10,741
Posted: June 03, 2004 at 10:25 PM / IP Logged
Basically, yes.  But rather than repeat what has already been written so well, refer to this thread on the General forum.  Cheers!
harvey1959
Copper - Posts: 94
Posted: June 03, 2004 at 11:27 PM / IP Logged
Thanks a lot. my man.
Harv
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
