Where to buy MDF spacers?
bfeeny
Member - Posts: 48
Posted: June 04, 2004 at 10:39 PM / IP Logged
Does anyone know of a place that sells good quality spacers made of MDF? I have seen plastic spacers for sale, but would prefer MDF, I realize many people make there own spacers, but wanted to see if there is a place selling them.
Brian
Ketel22
Silver - Posts: 976
Posted: June 04, 2004 at 11:55 PM / IP Logged
any thing that is prefab is going to be more expensive... mdf is so cheap just cut some. companies will probally charge you like 4 and 5x the cost
Quad L Handyman services
bfeeny
Member - Posts: 48
Posted: June 05, 2004 at 12:39 AM / IP Logged
The thing is, I have never made them before, and probably don't have good wood working skills. I don't own a scroll saw either.
Whats the easiest tool to use to make these rings? Scroll saw? Or is there a better tool to use?
Brian
kfr01
Gold - Posts: 2,121
Posted: June 05, 2004 at 12:49 AM / IP Logged
Brian,
I had 0 experience wood working before making some MDF brackets a month ago.
Go out, buy a $20 black and decker jigsaw and a $10 sheet of 3/4" MDF and have fun with it!  They are actually really easy to make.
Trace the speaker you'll use (a paper cutout probably came w/ the speaker), mark the hole locations, and start cutting it out.
Tip:  you can always _increase_ the size of the hole with a drill bit but can't decrease the size of the hole, so make your cuts on the inside of your lines.
New Project: 2003 Pathfinder
rknj01
Copper - Posts: 59
Posted: June 05, 2004 at 1:14 AM / IP Logged
selectproducts.com but its expensive
Sweekster
Silver - Posts: 481
Posted: June 05, 2004 at 2:40 AM / IP Logged
Brian,
Regardless of your skill at it, I  think you should try it yourself.  Every one of us who have even the smallest experience had to start somewhere.  The tip that Kfr01 gave is absolutely correct.  I would only add a painters respirator mask and not the cheap paper masks as mdf is a real dust maker. I mainly use it myself because I'm asthmatic.  As far as the skill/sabre saw,  here's one that's a good starter for you.  I actually did my first set of adapters out of 1/4 inch plywood (easier to cut and it's cheaper) just to get myself comfortable with the cutting.  They came out well.
Hope that helps.  It's really not as hard as you think.
Duane...
If you think you're confused, imagine how you feel.   Where to buy MDF spacers? -- posted image.
Friday, July 18, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
