2001 dodge ram 1500 w/ infinity
yorkie41979
Posted: June 05, 2004 at 8:52 AM / IP Logged
hi, installing a cd player in a 2001 dodge ram 1500 w/infinity sound from the factory. does this setup already use an amplifier? the wiring harness i bought for it has a amp wire on it, but i didn't connect it to the oen on the back of the cd player - and when i turn it on, i get no sound. does this wire just need to be connected?
forbidden
Platinum - Posts: 5,354
Posted: June 05, 2004 at 1:06 PM / IP Logged
Yes it does, connect it to the remote on lead of the new cd player.
yorkie41979
Posted: June 05, 2004 at 8:42 PM / IP Logged
still getting no sound. installing a sony xplode cd player. i tried using the remote turn on wire and didn't work, so then tried using the power antenna wire, didn't work either. any ideas? the radio does turn on, but no sound.
Manoftools
Copper - Posts: 55
Posted: June 05, 2004 at 8:51 PM / IP Logged
If one of your speakers is blown or a speaker wire is grounding out for some reason then your radio will not play sound.  It is possible that one of your speakers is on its way out, so try hooking up all your speakers individually and see if you get any sound.
00neon
Copper - Posts: 61
Posted: June 05, 2004 at 9:09 PM / IP Logged
i may be stupid for saying this, but make sure that the fuse for the radio isnt blown, if you installed it first with out the remote turn on wire connected, it could have grounded and blown the fuse for the radio.................2001 dodge ram 1500 w/ infinity -- posted image.
1 JL 12 w3 D4
1 MTX 421 D Monoblock
1 Sony Xplod 75x4
Front: Alpine SPX-177A
Rear: JL audio VR690-CXI
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
