1997 Honda Accord Wiring
aussieaccord
Posted: June 07, 2004 at 11:13 PM / IP Logged
I have a stock CD unit in the car and want to know which wire to split off to an amp...
I have heard blue from a few people but want to be sure
Moderator - Posts: 12,488
Posted: June 08, 2004 at 1:01 AM / IP Logged
If this is the OEM radio that you want to have control the remote turn on lead of an aftermarket amplifier, then use the BRWON/WHITE wire at the harness. Here's the pic of the plug: http://www.velocitymotorsport.com/images/install_notes/pins2.jpg
aussieaccord
Posted: June 08, 2004 at 8:12 PM / IP Logged
1997 Honda Accord Wiring -- posted image.
Sorry for the size of the image i dont know how to make it smaller. This is coming out of the CD player...I have OEM and recognise the plug, so you think i should split maybe off the speakers at the plug, not fron the unit itself?
Cheers
Posted: June 09, 2004 at 9:34 AM / IP Logged
What are you trying to add ? Did you want the OEM deck to turn on the amplifier that you added or did you need the speaker level outputs to go to your amp for high level inputs ?
Sunday, November 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
