Stereo Cut Out
martycoyote
Posted: September 07, 2002 at 3:08 PM / IP Logged
I have a Sony CD player and when I turn the volume up to more than quarter way, the system cuts out, can anyone tell me what the solution to this problem is?
Thanks, Marty.
marty coyote
Platinum - Posts: 12,488
Posted: September 07, 2002 at 5:07 PM / IP Logged
Check your ground.
accordracer
Member - Posts: 18
Posted: September 07, 2002 at 6:45 PM / IP Logged
There Could also be a short on one of your speaker terminals u might want to check that
msmollin2001
Member - Posts: 9
Posted: September 08, 2002 at 4:53 PM / IP Logged
Could you be a little more specific than "It cuts out"? I don't wanna sound condescending, but i dunno if you mean the sound cuts out, or the entire receiver/amp powers off. Also, is it at a specific volume level that this happens? Do you notice anything strange coming out of the speakers before it cuts out, or when you near this volume level? Thanks.
-Matt
wvsquirrel
Gold - Posts: 1,237
Posted: September 11, 2002 at 12:02 AM / IP Logged
I have the same problem with mine.  It's been said in other posts that Sony HU's are prone to skip at different bass levels if your system hits hard enough.
Squirrel
"No more Cpt. Kirk chit chat"
Donate to the12volt.com
martycoyote
Posted: September 12, 2002 at 2:00 PM / IP Logged
Thanks for the advice guys, in answer to msmollel2001 who wants more details, here you go;  When I say cuts out, I mean that the whole system temporarily loses power and then starts again where it left off and it will go again unless I turn the volume down quickly enough, the problem do not happen if I turn the bass down as low as it will go, but the kind of music I listen to needs a lot of base.  So you think it may be a Sony problem?
Thanks again, Marty.
marty coyote
martycoyote
Posted: September 12, 2002 at 2:02 PM / IP Logged
P.S.  I also notice that the lights dim on the stereo when the base notes hit!
marty coyote
bberman1
Gold - Posts: 2,314
Posted: September 12, 2002 at 2:58 PM / IP Logged
Do you have amps? What kind of speakers?  Can you please list your whole system so we can try to diagnose what the problem might be? Also if you have subs how many ohms are you running them @
Posted: September 12, 2002 at 7:08 PM / IP Logged
Another thing to check for is the face plate..... make sure that it's secure and if you move it around does it turn on/off like you said ??
chasesaccessori
Copper - Posts: 198
Posted: September 13, 2002 at 11:24 AM / IP Logged
You might have a lot af problems here or you might just have one.  We would need you system information befor we got down to the nitty gritty.
(owner/installer)
Chase's Accessories
Ridgecrest, CA
in business since 92
Saturday, March 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
