Noise
davedyer79
Copper - Posts: 178
Posted: June 24, 2004 at 4:09 PM / IP Logged
Okay guys, I have a factory deck in my 2001 Jeep Grand Cherokee and the Memphis 4 channel and 500d for the subs.  When I had an aftermarket deck in, everything was fine.  Put factory deck using stinger hi level convertor to the Memphis XO-3 3 way signal processor.  This piece gives me front/rear+sub output to my amps with only 1 hi level.
The problem is that I have a lot of horrible engine sound thru the speakers, with a loud pop out of my sub when the car is turned off.  I used the power/ground/remote off my factory deck wires to power the signal processor.  I know it is not with the RCA's or the amps, as it worked fine with an aftermarket deck.  Could it be the processor or the hi-level convertor?  I have also checked the gains on all my amps with the engine not running and everything sounded fine, but with the car running it sounds like a fast and furious race!!  Please let me know something guys.  Thanks a ton.
davedyer79
nollaz
Member - Posts: 44
Posted: June 25, 2004 at 2:56 AM / IP Logged
sounds like the line converter is being a piece. check the wires make sure nothing is touching eachother. make sure the box isnt put/mounted near any 12volt power lines as it will get ground noise(engine noise). and also make sure the converter box is grounded. there should be a black ground wire on it, if not then thats definatly the problem.
yup
Saturday, January 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
