1998 Honda Civic
Garagegoblin
Member - Posts: 8
Posted: September 09, 2002 at 8:49 PM / IP Logged
OK, I installed a aftermarket cd player for my g/f's car.  When I called Circuit City for some advice on the installation process, the guy warned me that I was going to lose my dome lite.  It does not have keyless entry.  And the dome light does work but only when it is switched on, and not when the door trigger.  The guy told me I had to find the wire that triggers the door light and connect it properly together.  Any idea on how I would learn which one I need to do it with, or any idea on how to fix it at all?
moshe
Member - Posts: 26
Posted: September 09, 2002 at 9:39 PM / IP Logged
did you use a honda conector?
Garagegoblin
Member - Posts: 8
Posted: September 09, 2002 at 9:58 PM / IP Logged
yea, I bought it from Circuit City.
moshe
Member - Posts: 26
Posted: September 09, 2002 at 10:04 PM / IP Logged
i have done 100s of those car never had aproblem like this
Garagegoblin
Member - Posts: 8
Posted: September 09, 2002 at 10:05 PM / IP Logged
well sh*t
moshe
Member - Posts: 26
Posted: September 09, 2002 at 10:10 PM / IP Logged
behind the radio there is a green connector or under the steering above the brake in this con check with test light i think green with red stripe
see if you got ground when you open the doors
Garagegoblin
Member - Posts: 8
Posted: September 09, 2002 at 10:15 PM / IP Logged
cool thanks
moshe
Member - Posts: 26
if yes you can run a wire directly to a light green red stripe (thik wire)in the left panel above the dash this wire go to the dome light from the doors triger
Chris Luongo
Platinum - Posts: 3,746
Posted: September 10, 2002 at 6:20 AM / IP Logged
In that extra, unused green plug behind the radio, there are simply two wires you must splice together.  After that, the domelight will function perfectly.
I always forget the colors...........my mind is telling me it's light GREEN/ red and light GREEN/ black..........but I could be completely dead wrong..........try to test the wires first, or at least get a couple more opinions before connecting them.
Garagegoblin
Member - Posts: 8
Posted: September 10, 2002 at 11:27 PM / IP Logged
thanks guys I will try it as soon as she trusts me to fix it.
Tuesday, November 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
