Kicker 2 ohm
julez
Member - Posts: 6
Posted: July 04, 2004 at 9:03 PM / IP Logged
just purchased kicker 650.4 ( 4 x 120 Watts @ 4 ohm )  or ( 4 x 170 @ 2 ohm ).
so i am going to wire 1 pair tweeters ( in series ) to 1 channel
and 1 pair mid range ( in series ) to another channel.
and the same on the other side of the vehicle.
has anyone here tried this method for there front end?? if so please let me know what the sound was like....was it better running 2 speakers in series ( giving 2 ohm rather than 1 speaker ( in 4 ohm )
i have not purchased front speakers yet so let me know what would be a good choice..
Thanks guys..
Other system details include.
Rockford symetry unit.
2 x rockford power 500s  each connected to 1 10" DVC rockford subs.
julez
Member - Posts: 6
Posted: July 04, 2004 at 9:37 PM / IP Logged
sorry i ment parallel connection..
Ketel22
Silver - Posts: 976
Posted: July 05, 2004 at 1:26 AM / IP Logged
you are going to have 4 speakers on each side of your car aside from the low end?
Quad L Handyman services
julez
Member - Posts: 6
Posted: July 05, 2004 at 2:18 AM / IP Logged
4 speakers each side at the front, yes...but they will be high end..
1-pair tweeters, each side (channel 1 and 2 )
1-pair mid range, each side ( channel 3 and 4 )
8 speakers in total in front
all cut over frequencys will be, pre amp via rockford system unit ( Epx )
forbidden
Platinum - Posts: 5,354
Posted: July 05, 2004 at 7:53 PM / IP Logged
So you are trying to make a killer front soundstage from what I gather and are going to be using double sets of speakers to accomplish this and at the same time parallel wiring all the speakers to 2 ohms per channel to get the most out of the amp. What are you going to be using to control the frequencies to these speakers? Are you after SQ or SPL for this system? You also should use the realistic 12.5 volt rating for your amp rather than using the best case scenario of always having 14.4 volts or better at your disposal. Thus the power ratings of your amp are 4 x 70w @ 4ohm or 4 x 135w @ 2 ohm. For SQ purposes you are far better off runing at 4 ohms rather than at 2. At 2 ohms everything basically doubles, things like heat (affects SQ), damping factor, current draw and the list goes on. Sure a gain of 3db is possible but at the expense of wound quality.
There are many questions yet to be asked and the first one is what speakers are you going to use in what vehicle and how are you going to separate the frequencies between the speakers properly if you plan on going this route. If it was myself I would use either 2 large 2 channel amplifiers to drive each set of components through their respective passive crossovers and drive them at 4 ohms. A substitute to the 2 2 channel amplifiers would be one large 4 channel amp driven at 4 channels at 4 ohms again through the proper respective crossovers. A note here that in order to gain the 3db difference in output levels a amp double the size in watts rms must be used. Thus if you have a 50 watt x 2 amp, a 3db gain means that a 100w x 2 amp must be used. I'm sure that Dyohn and some of the other will offer their .02 on this as well.
stevdart
Platinum - Posts: 5,816
Posted: July 05, 2004 at 10:21 PM / IP Logged
Too many speakers.  You're going to muddy up the sound, although right now I know you are just imagining the system.  Don't imagine that much stuff.  More doesn't always make better.  Get a pair of high quality components, and use your 4 channel amp to power them.  Bi-amp the components, using two channels for the tweeters and two channels for the mids...and you'll be ahead of the rest of the class.  Do you have a local dealer where you can audition some components?
