Rear Deck Regal
tekk
Member - Posts: 18
Posted: September 05, 2004 at 9:17 AM / IP Logged
I am trying to instal some 6x9's in the rear deck of my '91 Regal, but the rear deck crumbled with age. The carpet and cardboard like material crumbled to dust when I was trying to reinstall it and I need some help. I am wondering if anyone knows if its possible to find a replacment or ideas on how to make it myself. Thanks.
-TeKK
NoPo 4 Life
Chad7n7
Silver - Posts: 408
Posted: September 05, 2004 at 9:58 AM / IP Logged
what we usually do is build a new rear deck out of 1/2" MDF, If there is anyway that you can salvage the old one just enough to outline and get a template, that would be the easiest. If not, then use a piece of cardboard and trim to fit the rear deck, transfer to MDF, and you should get the results you are looking for.
tekk
Member - Posts: 18
Posted: September 05, 2004 at 10:01 AM / IP Logged
Where can I get my hands on MDF?
-TeKK
NoPo 4 Life
Chad7n7
Silver - Posts: 408
Posted: September 05, 2004 at 10:37 AM / IP Logged
try any local hardware or lumberyard. MDF is Medium Density Fiberboard.
thapimpfromchi
Silver - Posts: 616
Posted: September 05, 2004 at 7:35 PM / IP Logged
menards, home depot, builders square lowes, handy andy... i dunno which u have around you, but any of those should have it
1990 Honda Civic HB:
Clarion DXZ545MP H.U.
2- 6.5" Power Acoustik interiors
Diamond Audio 600.1 amp
Diamond Audio 15" M6MKII
Pyramid PB881X 4 CH. Amp
stratusfear69
Member - Posts: 40
Posted: September 06, 2004 at 5:30 PM / IP Logged
Can't u just mount those speakers in the trunk?  Hold them into the opening of the rear deck, and screw up into the sheetmetal.
/r7
Silver - Posts: 340
Posted: September 06, 2004 at 7:30 PM / IP Logged
my buick, beit a lesabre, should be similar in mounting i would assume.
and i mount from inside the trunk where the 2 stock baffles were. you didnt try and access the speakers from the deck itself in the cab did you? you may have to make the cutout chad mentioned so you have the rear deck.
The mounts in the back arent connected to the cardboard, they are connected to the unibody and accessing them is easier than i've seen in most cars, since you can fit into the trunk itself and work on things hehe :-).
hth
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
