jl 10w3 box volume
mxxmikexx
Silver - Posts: 796
Posted: September 10, 2004 at 1:45 PM / IP Logged
does anyone know how much air space i need for a sealed enclosure for a jl audio 10w3 ?
jeffchilcott
Platinum - Posts: 2,483
Posted: September 10, 2004 at 3:41 PM / IP Logged
are they older 10 w3's or are they new or are they 10w3v2?     let me know that and I can tell you
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
mxxmikexx
Silver - Posts: 796
Posted: September 10, 2004 at 3:43 PM / IP Logged
the older ones, i found a forum posting saying .65 cubic feet, does that sound right?
jeffchilcott
Posted: September 10, 2004 at 4:18 PM / IP Logged
for the DVC model yes thats right for a space save sealed enclousure.    realy I would go with about .85.     Or vent
2007 World Record
mxxmikexx
Silver - Posts: 796
Posted: September 10, 2004 at 5:21 PM / IP Logged
what size would you go with in a ported enclosure, and what size port? the box is going in a hatchback, and im looking more for a good sounding box as opposed for bass heavy
12-volt_guy
Copper - Posts: 53
Posted: September 10, 2004 at 7:55 PM / IP Logged
The better sounding box is probably going to be sealed.  Ported enclosures are more efficient when it comes to low frequency output, but this is at the sacrifice of control.  The sound starts sounding boomy and once down to a certain frequency, the woofer is actually running "free-air".  And have you ever heard woofers mounted free-air?
For 10W3-D2, optimum sealed: 0.625 cu. ft. ........ ported: 1.0 cu. ft.
For 10W3-D4 sealed: 0.625  .......  ported: 1.25 cu. ft.
For 10W3-D6 sealed: 0.75 cu. ft.  ......... ported: 1.25 cu. ft.
jeffchilcott
Posted: September 11, 2004 at 11:20 AM / IP Logged
Im gonna go ahead and say no to that one.   I have never had a properly vented box make a sub sound like it is in free air...Maybe pre fab boxes sound like garbage and boomy.    but if you build your own you can be very impressed with what you can do
2007 World Record
12-volt_guy
Copper - Posts: 53
Posted: September 11, 2004 at 12:59 PM / IP Logged
You can say no, but if you research enclosure design, you will find that this is true.  I didn't say that a ported box would sound as bad as free-air, but that at lower frequencies, the driver *is* operating at free-air, and the sound is not as accurate as a sealed enclosure.
12-volt_guy
Copper - Posts: 53
Posted: September 11, 2004 at 1:03 PM / IP Logged
Look at home subwoofers.  Inexpensive ones are always ported because this design makes better use of the cheaper low-power amps.  The higher quality subs are almost always sealed.
