Router Question
jonbth
Member - Posts: 42
Posted: September 13, 2004 at 1:56 PM / IP Logged
I want to build a sub box because I can't find any pre made ones the size I want.
I'm going to buy a router and was wondering if someone can explain to me what the difference between a "plunge" router and a regular router.
I'm not an idiot. I just don't have any experience using a router.
DYohn
Platinum - Posts: 10,741
Posted: September 13, 2004 at 1:59 PM / IP Logged
As far as I know a router is a router.  The difference is in the tool or "bit" that you use.  A plunge bit has a pointed tip that can start its hole all by itself and a regular bit requires you to drill a pilot hole before you begin.
Dragonma15
Posted: September 13, 2004 at 3:14 PM / IP Logged
A plunge router has a spring loaded base.  You simply push down on the router to " plunge" the bit into the work piece.  A regular router needs to be adjusted to the height of the work piece.  The regular router lacks the " plunge" feature.
jonbth
Member - Posts: 42
Posted: September 13, 2004 at 3:39 PM / IP Logged
Which router would I be better off buying for building a subwoofer box? I'm just going to use it to cut holes.
furflier
Copper - Posts: 236
Posted: September 13, 2004 at 3:44 PM / IP Logged
I personaly like the plunge router. You can preset the depth that you want and lock it into place. It doesn't make much diff. because they do the job pretty much the same way.
sparkie
Platinum - Posts: 2,061
Posted: September 13, 2004 at 4:02 PM / IP Logged
If your budget allows it, you can purchase a router that has both a fixed and a plunge base. Plunge routers are usually more expensive. Most larger hardware/home renovation stores have a good tool section. They can explain the diiferences between the two types.
sparky
DYohn
Posted: September 13, 2004 at 4:44 PM / IP Logged
AH.  Thanks for the clarification and now I am educated!
forbidden
Platinum - Posts: 5,354
Posted: September 13, 2004 at 8:12 PM / IP Logged
A plunge router works great when it is permanently attached to a perfect circle jig or any other jig. A fixed router works great for all other applications.
