Lumina Wiring Harness
joeycarroll
Posted: September 22, 2004 at 9:23 PM / IP Logged
Hi , I have a 93 Chevy Lumina . The radio  & factory harness was missing when I bought it . I want to replace it back with a factory equipment . I have a stock radio & I found a harness in the salvage yard . Here is my problem . I don't have a problem with most of the wires , except there are 2 grey , 2 yellow & 2 brown . How do I tell which ones go where ? I hooked everything up & took a 50/50 chance on the grey , yellow & brown . The radio worked , but the fade & balance didn't work right . How do I find out a what the difference is between the colors ?
Thanks!!
Joey
SoundFX411
Copper - Posts: 153
Posted: September 23, 2004 at 6:54 AM / IP Logged
Sounds like the speakers aren't hooked up correctly.
Drivers Front= Tan+
              Gray-
Drivers Rear= Brown+
                   Yellow-
Pass Front= light green+
            dark green-
pass rear= dark blue+
           light blue-
Try this hook up. Hope this helps
kgerry
Platinum - Posts: 3,455
Posted: September 23, 2004 at 1:45 PM / IP Logged
the speaker connections are bundled together, so the grey that is right beside the tan is a speaker wire ( along side the light green and dark green ), the yellow and brown that are right beside the dark blue and light blue are the left rear speaker wires.....
if you got the plug assy with the three separate connectors then its easy because two of the connectors only have 4 wires each and these are all speaker wires... the plug with 6 pins contains the power, ground, dimmer, power ant, etc , etc
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
forbidden
Platinum - Posts: 5,354
Posted: September 23, 2004 at 2:27 PM / IP Logged
www.installdr.com should list the wire colors for this vehicle.
