RF Modulated Changer in '02 Mercedes C230
callmeraven
Member - Posts: 17
Posted: September 25, 2004 at 8:59 PM / IP Logged
I'm looking to put a Pioneer RF modulated 6-disc changer into an '02 Mercedes-Benz C230 Kompressor coupe. I went into the back of the panel and removed the passenger side panel to find the Bose box with the factory sub. I was hoping to find the European antenna there with the fiberoptic stuff and the cell phone antenna. I had no such luck, however. I found what appears to be the cell phone antenna connection (it's a coaxial cable with a connection that is screwed together), then there is another similar coaxial connection that is not connected to anything. Other than that (and a serial connector), there is nothing that I can find there to hook into. Any suggestions on where to look or what to do from here? I'm not sure if that coax line that's not connected is the antenna or not -- I'd think if it were the antenna, it'd be hooked up to something (since he's getting reception fine).
Help or suggestions would be greatly appreciated.
mo12v
Posted: September 26, 2004 at 4:42 PM / IP Logged
I beleive it's Fiber Optic and is in Trunk.  Factory Changer only
MO
Esco1977
Member - Posts: 46
Posted: September 28, 2004 at 9:29 PM / IP Logged
my girl has a 02 c230 coupe and the changer works throught the factory head unit and its in the glove box.... hope this helps
Friday, September 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
