4 Channel Amp, Different Loads
dxav
Silver - Posts: 314
Posted: September 28, 2004 at 10:56 AM / IP Logged
This is the scenario:
I have a 4 channel amp. It is tri-mode capable, and I would like to run a set of components to the front on channels 1 and 2 (Stereo - 4 Ohms). The rear fill is a pair of 6x9", and I want to put them on channel 3 and 4. I also want to bridge a 10" 4 Ohm sub across channels 3 and 4 (hence tri-mode).
The question:
It is safe to run 1/2 the amp at a 4 Ohm load, and the other 1/2 of the amp at another load? The specs mentioned it is ok to run anywhere from 2-4 Ohms, but the only situation they give is running tri-mode across both channels. Basically, running a sub bridged on each channel with a pair of speakers run in stereo mode on each channel.
So is this safe? I know the wattage is ok, it's not a concern, I just want to know if this is a viable installation and safe for the amp.
Thanks,
DXAV
DYohn
Platinum - Posts: 10,741
Posted: September 28, 2004 at 11:10 AM / IP Logged
Yes, it is safe assuming you use the proper crossover for the "tri-mode" side.  You will need to use a passive low-pass for the sub and a passive high-pass for the 6X9's set at the same frequency point (80 Hz is usually recomended.)  Set the amplifier crossover to "full" or off.
dxav
Silver - Posts: 314
Posted: September 28, 2004 at 1:18 PM / IP Logged
Thanks for a second opinion. Logically it seemed to work, but I didn't want to risk damaging the equipment with a full test.
Got the cap and inductors already, too.
DXAV
jeffchilcott
Platinum - Posts: 2,483
Posted: September 28, 2004 at 6:13 PM / IP Logged
watch yourself normally when you run in tri mode you have a to run a 8 ohm speaker o the tri channel     you might want to consider wiring your 6x9's together to 8 ohm and use that in tri mode.   then run your subs on the 3/4 channel
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
Ravendarat
Platinum - Posts: 2,806
Posted: September 28, 2004 at 6:24 PM / IP Logged
I dont understand why you dont just run your 4 speakers off channel 1 and 2 and then the sub bridged off channels 3 and 4. You loose fader control but it is much more practical and then you can just use the build in crossovers.
jeffchilcott
Posted: September 28, 2004 at 6:33 PM / IP Logged
i will agree to that as well I have done a few set ups for people on a tight budget
2007 World Record
Tuesday, March 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
