4 channel amp with one sub
curt234
Member - Posts: 42
Posted: October 03, 2004 at 2:41 PM / IP Logged
Got a legacy 600 watt 4 channel sub. Was wondering if there was any way I got bridge both channels and run one sub to get max power???
jeffchilcott
Platinum - Posts: 2,483
Posted: October 03, 2004 at 3:05 PM / IP Logged
i am guessing you mean you got a legacy 4 channel amp and a sub not a 4 channel sub   haha..   but no you can bridge a 4 channel amp to one sub unless it is a DVC and last i checked legacy didnt make a DVC sub. you will have to run it off 2 channels those you can bridge if you amp will run a 2 ohm mono load.....figureing this based on most legacy subs are 4 ohm,    you need to let us know the model #'s and bridging capacity of your amp and what model sub
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
kfr01
Gold - Posts: 2,121
Posted: October 03, 2004 at 3:32 PM / IP Logged
Why would the amp need to be able to run 2-ohm mono to bridge 2 channels into a single 4ohm sub???  Wouldn't the amp simply see 4-ohms when bridged?
New Project: 2003 Pathfinder
jeffchilcott
Posted: October 03, 2004 at 5:34 PM / IP Logged
if it is bridged each side would see a 2 ohm load.    some legacys wont even do a 2 ohm load bridged
2007 World Record
curt234
Member - Posts: 42
Posted: October 03, 2004 at 9:59 PM / IP Logged
The sub is a pioneer I tried bridgeing channel 1,2 and 3,4 but the sub don't work
kfr01
Gold - Posts: 2,121
Posted: October 03, 2004 at 10:25 PM / IP Logged
I'm sorry, your statement is wrong.
"Some people say that when an amplifier is bridged onto a 4 ohm load, it 'sees' a 2 ohm load. While it is true that the same current flows whether the amp is bridged on a 4 ohm load or a 2 ohm stereo load, the amplifier is driving a 4 ohm load across its outputs. A single 4 ohm speaker can never be a 2 ohm load."  http://www.bcae1.com/bridging.htm
I think you mean to say this:   If the amplifier is 2 ohm stereo stable (stable with 2-ohms on either of the stereo channels), then it is 4 ohm bridgeable.
Almost no amps are 2-ohm stable in bridged mode.
