99 F-150 radio tied to Airbag?
luis0290640
Member - Posts: 12
Posted: October 07, 2004 at 6:54 PM / IP Logged
Father recently purchased a 99 F-150 extended cab. I just recently installed a aftermarket stereo (Kenwood). For some reason the Airbag light on the dashboard stays on and the cut-off switch for the airbag donesn't ork anymore. In anyway is the factory radio tied in with the airbag? Everything worked fine prior to installing radio. Any suggestions? please help....
Luis
mo12v
Posted: October 07, 2004 at 7:39 PM / IP Logged
Check ALL wiring again, and check the wires going to Air Bag switch.  Did U blow any fuses hooking up these wires?
MO
