2001 pontiac grand prix
eazyinstaller
Posted: October 11, 2004 at 10:01 PM / IP Logged
Anyone know if on a 01' grand prix the factory head unit has to stay installed or can it be removed and replaced with an after market unit without keeping the original installed ?
mo12v
Posted: October 11, 2004 at 10:17 PM / IP Logged
U can replace Factory Radio
Use the Metra Kit # 99-4000 and wire adapter # 70-1858 and Antenna adapter # 40-GM10
MO
cerwinvega4
Member - Posts: 12
Posted: October 12, 2004 at 1:30 AM / IP Logged
To keep all the factory features that run through the factory radio now, you will have to relocate the fact. deck. For a 01 GM vehicle, it will more than likely be the case, although different GM vehicles have different funstions running through the fact. unit. Some cars will lose more features then others. The obvious thing you will lose is your door chime. If the door chime is coming through your front left passenger speaker, that means you have one a radio that should be relocated so you wont lose any features.
mo12v
Posted: October 12, 2004 at 9:09 AM / IP Logged
AS Stated:
That is not a DATA Type radio
U can replace the Factory radio with ??what ever??
U can use the kits I posted
MO
eazyinstaller
Posted: October 21, 2004 at 5:28 PM / IP Logged
thanks mo12v where can i get those adapter kits?
marchingant
Member - Posts: 6
Posted: October 22, 2004 at 1:51 PM / IP Logged
I got all of those at my local Best Buy. Also, pretty much any store that does stereo installation should carry those parts. You may find a place to get them cheaper, or you can order online from the various online stores.
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
