2003 Mazda 6
meh66
Copper - Posts: 266
Posted: October 17, 2004 at 8:20 AM / IP Logged
Do anyone have the wiring info for the 03 Mazda 6?
MEH66
"Car Performance and Mobile Electronic Enthusiats"
boomer_106
Silver - Posts: 710
Posted: October 17, 2004 at 9:38 AM / IP Logged
Mazda
Mazda-6
2003
Remote Starter  Wiring Colors and Notes
Function
Vehicle  Color
Location
Start:
BLACK/ Blue (+)
Ignition switch harness
Ignition  #1:
Blue (+)
Ignition switch harness*
Ignition #2:
N/A
Ignition  #3:
N/A
Accessory:
BLACK/ Red (+)
Brake  Light:
Green (+)
Brake pedal switch
Tach  Signal:
N/A
Parking Lights:
Lt.GREEN/ Black (+)
Drivers kick panel
Headlights:
N/A
OEM Alarm  Disarm:
Blue (-)
Drivers kick panel
OEM Alarm  Arm:
N/A
Diesel  Glow Plug:
N/A
Clutch  Bypass Wire:
N/A
Notes:
 *This vehicle is equipped with a Transponder Anti-Theft Security System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number.
Mazda
Mazda-6
2003
Alarm and Keyless  Entry Wiring Colors and Notes
Function
Vehicle  Color
Location
Constant  +12 Volts:
Black and BLACK / YELLOW (+)
Starter  Kill:
BLACK/ Blue (+)
Ignition  +12 Volts:
Blue (+)
Dome  Lights/Superv:
Yellow/Black (-)
Drivers kick panel or door lock module**
OEM Horn:
PURPLE / White (-)
Steering column or door lock module**
Power  Lock:
Lt.Green (-)
Power  Unlock:
Lt.Green (-)
Trunk  Release:
Yellow (-)
Switch or door lock module
Alarm  Input Wire:
Yellow/Black (-)
Notes:
**The door lock control module is located above the passenger kick panel. Lock is negative trigger through a 1.4k ohm resistor. Unlock is a straight negative trigger. See Note #211 Single Wire Negative Trigger Door Locks
meh66
Copper - Posts: 266
Posted: October 17, 2004 at 10:06 AM / IP Logged
Thanks for the info, but let me clarify. I was looking for information on audio, I wanted to know the speaker color code.
MEH66
boomer_106
Silver - Posts: 710
Posted: October 17, 2004 at 10:21 AM / IP Logged
Oh sorry about that. I always buy a wire harness for the vehicle. They are cheap and eliminate all the hassle.  If I had the colors I would post them but, I dont.
