Right size fuse
mpathy
Member - Posts: 47
Posted: October 20, 2004 at 2:58 PM / IP Logged
   What is the right size fuse for me to use . I am running 4ga wire from my battery to my .5 capasitor . 8ga wire to my amps.
   I have a total of about 600watts .
  What would be the right fuse to put in between the battery and the capasitor?
Francious70
Silver - Posts: 629
Posted: October 20, 2004 at 3:42 PM / IP Logged
Bout a 40A fuse
Paul
dxav
Silver - Posts: 314
Posted: October 20, 2004 at 3:53 PM / IP Logged
mpathy,
40A is too low, I think.
If....
I = Watts/Volts
I = 600W/12V (bare minimum, expect closer to 14 when the car is on)
I = 50 Amps
If you draw nominal power from the system, 40A should be ok, but when you draw more current, you could blow a 40A quite often. Or you could put a 40A in and just never turn your system up loud.
Anyone else agree or disagree?
DXAV
haemphyst
Platinum - Posts: 5,059
Posted: October 20, 2004 at 3:58 PM / IP Logged
Truthfully, you can put ANY size fuse up to 150 amps. you DO NOT RATE THE FUSE BASED ON THE AMPLIFIER CURRENT, you rate the fuse based on the current capacity of the primary wire, in this case, a number 4, which will handle 150 amps. The fuse under the hood is NOT there to protect the amps, but to protect the car. HOWEVER, if you were to base it on the current requirements of the amps, then I would do the math like this -
600 watts at 50% efficiency is 1200 watts in, 1200 divided by 14.4 (the voltage with the car running) equals 83.33333333 amps, so I would put an 85 amp fuse in line, as it is a much more readily avialable fuse than an 83.33333333 amp fuse.
ravenndude
Silver - Posts: 250
Posted: October 20, 2004 at 3:59 PM / IP Logged
^^^ he's got it!
mpathy
Member - Posts: 47
Posted: October 20, 2004 at 8:46 PM / IP Logged
       Thank you all for the help
