Remote Wire
korndogg
Member - Posts: 6
Posted: October 23, 2004 at 2:24 AM / IP Logged
Does anyone know what color the remote wire is on a 99 silverado??? I cant find it anywhere.
Rushman
Silver - Posts: 380
Posted: October 23, 2004 at 10:10 AM / IP Logged
Do you mean from the factory head unit? It probly doesnt have one. If you need a remote wire to run for amps or somthing off the factory deck , you can run the remote to a spare spot at the fuse block to a "switched" or acc. 12v spot using a spade terminal.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
6 kicker SS65.2 components
meh66
Copper - Posts: 266
Posted: October 23, 2004 at 10:31 AM / IP Logged
Hey Korndogg,
I believe a the switch 12 volt wire on this car is yellow behind the HU. I agree with Rushman as it would be easier to use a spade terminal to get it off the fuse block.
MEH66
"Car Performance and Mobile Electronic Enthusiats"
korndogg
Member - Posts: 6
Posted: October 23, 2004 at 1:33 PM / IP Logged
well the wierd thing is....i got the wiring diagram from here and it said one of the speaker wires is yellow...and then it also says the 12v wire is also yellow?
Rushman
Silver - Posts: 380
Posted: October 23, 2004 at 2:13 PM / IP Logged
the speaker wire should have a trace line of another color on it while the 12v wire is solid yellow.
99 F-one fitty
Pioneer Premier H/U
Alpine EQ
Kicker 1200 amp
4 Kicker comp 10s
korndogg
Member - Posts: 6
Posted: October 24, 2004 at 12:04 AM / IP Logged
here...this is where i got the info from...
https://www.the12volt.com/installbay/detail.asp?info=alarm&year=1999&make=Chevrolet&model=Silverado&ID=17458&type=Stereo
bumpingjeep
Copper - Posts: 149
Posted: October 24, 2004 at 12:16 AM / IP Logged
try one...and if it doesn't work...try the other...worst case scenario is that you will blow a fuse...not likely though unless your rear driver side speaker is blown...once again you will not hurt the speaker or the deck if you accidentally hook it up to the rear driver - spkr wire...
korndogg
Member - Posts: 6
Posted: October 24, 2004 at 12:29 AM / IP Logged
well i hooked it up to the yellow wire and blew a fuse...so i have no idea...i might just run the remote to the fuse box.
bumpingjeep
Copper - Posts: 149
Posted: October 24, 2004 at 1:28 AM / IP Logged
try the other yellow wire now...
korndogg
Member - Posts: 6
Posted: October 24, 2004 at 11:48 PM / IP Logged
there is no other yellow wire.
