PT cruiser radio removal
naughtydog
Copper - Posts: 90
Posted: October 26, 2004 at 2:52 PM / IP Logged
I have searched the board but not found any info. Can anybody give me a heads up on the radio removal from a PT cruiser.
I have one with poor reception and need to check connections - aerial.
Does anybody know if there are any isssues with these cars and poor radio reception??
Naughty
NowYaKnow
Gold - Posts: 1,217
Posted: October 26, 2004 at 5:18 PM / IP Logged
Look at the top of the trim bezel that surrounds the radio. Pop out the piece at the top center (window controls?) and unclip it to reveal a screw to remove. I think you also have to pull the heater/ac knobs off as well they should just pull straight off without much force.
Mike
gus1
Gold - Posts: 1,013
Posted: October 26, 2004 at 10:45 PM / IP Logged
Check the splice behind the glovebox. Also check the antenna base for corrosion/decent contact with the sheetmetal.
Gus
