2002 Toyota 4Runner Diagram
Norton5150
Posted: November 20, 2004 at 4:07 PM / IP Logged
Help I need a wiring diagram for a 2002 Toyota 4Runner Head unit.
I've searched through the forum and can't find what I need, I hoped it was close to some of the existing entries like other 2002 toyota's or close year 4 runners, but none of the wiring diagrams are correct for what I see in my truck.
The colors on the factory harness are as follows:
Grey w/Black stripe
Blue w/Black stripe
Black
Pink w/Blue stripe
(Light Green
Purple  ) those two are bundled together
Brown
(White
Red
Green
Yellow
Black
Blue)  those 6 are bundled together
and like an idiot I cut the stock harness off already so a wireing harness isn't going to help me
Also does anybody know why there is a standard antenna lead, and then another smaller lead that looks like an antenna lead?  What do I need to do with that smaller lead on my new stereo?
THANKS IN ADVANCE
customsuburb
Gold - Posts: 1,813
Posted: November 20, 2004 at 4:40 PM / IP Logged
Here are the harnesses from Metra:
toyota 4runner - metra online. One of the wiring harnesses on that page will replace the one you cut off.
Norton5150
Posted: November 20, 2004 at 4:59 PM / IP Logged
Thanks, but I guess my point was because I've already cut off the factory harness there is no point to me buying a harness and rewiring everything to that harness, I'm just going to wire directly to the new stereo's harness.  Unfortunatly I need to know what all the wires are to do that.  Does anybody know the wires?
forbidden
Platinum - Posts: 5,354
Posted: November 20, 2004 at 6:16 PM / IP Logged
See if your wire harness colors are listed at www.installdr.com
Norton5150
Posted: November 20, 2004 at 6:28 PM / IP Logged
No unfortunately I've been there already, everybody selling wiring harnesses or that has a wiring diagram thinks that all 1987 & forward Toyota's are the same, but they aren't.  All the wiring diagrams have 2 plugs one 10 pin and one 6 pin.  Well my 2002 4 Runner has one 20 pin plug.  I thought I could just line up the colors but they don't match either.  The closest thing I've been able to find that is correct for my truck is this link:
http://carstereohelp.net/wireharness_Toyota5.htm
which does indeed look correct for the back of the factory stereo and the 20 pin plug, but if that is correct, I don't understand it.  Pin's 10 & 20 are not connected to any wire so I have no ground,  I'm guessing 3&13 make up my power antenna, 2&12 make up my illumination.  But where is the rest of the speaker connections?  It only lists Front right +, front right -, rear right +, and rear left -, what about the missing 4 connections?
And I have no idea what beep or mute do (I'm assuming mute is for a cell phone).
Ahhhhh any help is greatly appreciated....
