12 volt stereo
minion7
Member - Posts: 8
Posted: November 23, 2004 at 9:45 AM / IP Logged
ok i am a student that is need of help i am supposed to make a car stereo JUSt run off a 12 volt battery inside a classroom. THIS is important to me so any help will be appreciated
birkett
DYohn
Platinum - Posts: 10,741
Posted: November 23, 2004 at 10:22 AM / IP Logged
What's your question?  To run 12 volt equipment off a car battery, make sure the battery is charged up and, err, just hook it up.  :)  Be sure to connect the head unit's memory and constant power wire to the + terminal.
kgerry
Platinum - Posts: 3,455
Posted: November 23, 2004 at 10:42 AM / IP Logged
and of course have speakers to connect to it.......
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
minion7
Member - Posts: 8
Posted: November 23, 2004 at 10:51 AM / IP Logged
i just want to hook up the 12 volt battery to the stereo nothing else
birkett
Ravendarat
Platinum - Posts: 2,806
Posted: November 23, 2004 at 11:36 AM / IP Logged
OK so take your black wire marked ground or negative and connect it to the negative post on your charged 12 volt battery. Them take the yellow wire marked battery or constant or memory and hook it up to the positive post. Then take the red wire marked ignition or switched and hook it up to the positive post as well. You will be rollin then
minion7
Member - Posts: 8
Posted: November 23, 2004 at 2:34 PM / IP Logged
alright thanks you guys ill be here for a while
birkett
jeffchilcott
Platinum - Posts: 2,483
Posted: November 23, 2004 at 3:47 PM / IP Logged
you might want to make sure you fuse everything properly, I dont think things will go so well for you if the radio starts smoking
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
minion7
Member - Posts: 8
Posted: November 24, 2004 at 9:18 AM / IP Logged
alright if all goes well what should i do to hook up the attenia,
birkett
dxav
Silver - Posts: 314
Posted: November 24, 2004 at 9:23 AM / IP Logged
What is the point of this again? This is a school project? Why such a menial task? No challenge?
Confused....
DXAV
minion7
Member - Posts: 8
Posted: November 24, 2004 at 9:28 AM / IP Logged
wanted to do somthing simple and that is all he aquires, his radio hardly gets any reception and he wanted us to make a radio with good reception adn a car stereo gets good reception so thats what i was think ing about doing.
birkett
Thursday, April 23, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
