Ford Excursion
jdomnick
Posted: November 23, 2004 at 10:19 PM / IP Logged
HELP PLEASE!
2002 Ford Excursion Third Row Speakers which speaker wire is negative (-) or (+)
Driver Side - Brown w/ yellow stripe & Brown with white stripe
Passenger side - Brown w/ Green Stripe & Black w/ pink stripe
jd
Ravendarat
Platinum - Posts: 2,806
Posted: November 23, 2004 at 10:24 PM / IP Logged
I cant remeber which is which but here is a simple test. Unlug a speaker and hook up a pair of speaker wires to the speaker, or just cut the plug off and leave a little wire on the plug. Then take a regualr 9 volt batter and touch one wire to the positive and the other wire to the negative. The speaker will make a thump sound and the speaker will either move in or out. If it moves out then you touched the positive wire to the positive post on the battery and same with the negative. If the speaker sucks in then you got the wires backward. Very easy test and is gaurenteed to work every time.
jdomnick
Posted: November 23, 2004 at 10:37 PM / IP Logged
Ravendarat
I wish I knew that an hour ago as I already assemble the body panels... Any other tricks that don't require a visual on the speaker? Thanks for the help!!!
Jake
jd
jdomnick
Posted: November 24, 2004 at 11:32 AM / IP Logged
Ford Excursion -- posted image.
Would anyone agree that the positive and negative points that are penciled in are correct. I am not sure if I am reading the print correctly. Thanks!
jd
