94 seville jvc head unit install
ratherbriding99
Posted: November 25, 2004 at 12:22 AM / IP Logged
Okay i have a 94' caddilac seville, non bose. It has the 10 ohm speaker setup. I bought the metra head unit mount kit and harness 70-2001. this harness doesn't come anywhere near matching the plugs off the stock head unit. Is it the wrong adapter or am i doing something completely wrong?
ratherbriding99
Posted: November 25, 2004 at 5:42 PM / IP Logged
nobodys put a aftermarket head unit in?
Chad7n7
Silver - Posts: 408
Posted: November 26, 2004 at 9:41 AM / IP Logged
on this application, there is a box in the trunk, either on the passenger side wall, or on the rear deck, I can't remember right off on the seville, you will find your harness there, you will also need an antenna extension, the antenna is actually in there also. This is actually the brain for the head unit in the trunk, the dash is more of a sending unit. Never did care for working on Cadillac's for this reason.
ratherbriding99
Posted: November 26, 2004 at 5:58 PM / IP Logged
so do i need to run a custom wiring harness to the trunk?
Chad7n7
Silver - Posts: 408
Posted: November 26, 2004 at 9:11 PM / IP Logged
The way we usually do it, it is a standard GM harness, which is the 70-2001 you already have, and run wires to the dash from the trunk. I am not sure if they actually do make a long harness for this application, though they may, we just run our own.
ratherbriding99
Posted: November 27, 2004 at 3:05 AM / IP Logged
so do i just by pass all the wires in the dash and run it strait to the trunk? Thanks sooo much man
Thursday, October 9, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
