looking for 8 scanspeak midbass specs?
bullman96
Silver - Posts: 294
Posted: November 25, 2004 at 1:18 PM / IP Logged
I have a pair of 8" scanspeak midbasses.  the model is pw21wo-20-08   08 ohms  903.   i know they can handle about 100 watts rms each.  i had them in a ported box and want to put them into 2 small sealed boxs and throw them in my truck, am lacking in the midbass.  i have mbquart pce216's so they will be pretty even.  will bridge the amp and wire the 8's in parallell so i get a 4ohm load.  does anyone have the spec sheet on this model as i lost it?  also, what would be the best crossover point and slope between the 8's and the quarts?  i was thinking around 200-250hz.  i guess it all depends on how the boxs do in the truck. thanks
DYohn
Platinum - Posts: 10,741
Posted: November 25, 2004 at 1:33 PM / IP Logged
Don't recognize that part number.  21W is tha designation for Scan-Speak's 8" woofers, but the only models I know have numbers like 21W/8551, 21W/8554 and 21W/8555.  Check with Madisound.
bullman96
Silver - Posts: 294
Posted: November 25, 2004 at 1:39 PM / IP Logged
yeah, i was going to email them tomorrow as i bought them from them a couple of years back.  will wiring them in paralell to bring them to a 4 ohm load be ok when bridging the amp, and can i wire them in paralell at the amp?  i found this serial number on the surround sr 185/13
bdl666
Silver - Posts: 330
Posted: November 25, 2004 at 3:06 PM / IP Logged
bullman96
Silver - Posts: 294
Posted: November 25, 2004 at 6:50 PM / IP Logged
by golly, i think you are right.  would this woofer be suited for the application i am going to use it in?  the quarts are rated at around 130 watts rms.  it looks the same, though the label in the pic is completely different.
Tuesday, March 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
