Complete Head Unit re-wire
leading_edge
Member - Posts: 10
Posted: November 29, 2004 at 6:33 AM / IP Logged
i recently bought a TE Gemini and want to install a head unit. i want to completely re-wire it so i know that everything is going to work first time.
can somebody explain to me how to do this? what is needed?
thanks in advance
bullman96
Silver - Posts: 294
Posted: November 29, 2004 at 7:00 AM / IP Logged
it is relatively simple. get some 10awg and run it from the battery, to your dashboard. make sure you put a fuse on it near the battery that is rated the same as the deck or the most the wire can handle. then run your ground wire from the deck to where your amps are or will be and ground them all at the same spot. then run your remote wire and rcas down the opposite side of the car that the battery wires come in. the only 2 stock wires that you will use because it dooesn't matter how clean they are will be the acc wire that turns the deck on and if you have it, the power antenna. there is no point also in rerunning you antenna wire either, just plug it in. if you are running the speakers off the deckthen either use the existing wires or run all new ones.
bullman96
Silver - Posts: 294
Posted: November 29, 2004 at 7:01 AM / IP Logged
what is a te gemini anyways? dont know that car
leading_edge
Member - Posts: 10
Posted: November 29, 2004 at 7:09 AM / IP Logged
it is an Australian car. Holden Gemini
click here >>>> http://www.hotgemini.com/cgi-bin/gallery3.cgi to see HEAPS of pics
leading_edge
Member - Posts: 10
Posted: November 29, 2004 at 7:11 AM / IP Logged
thanks heaps for the info as well :D
bullman96
Silver - Posts: 294
Posted: November 29, 2004 at 7:20 AM / IP Logged
talk to the guys who are on that site, things might be a bit different butit looks relatively easy to do. shouldnt take too long to run the wires.
leading_edge
Member - Posts: 10
Posted: November 29, 2004 at 7:21 AM / IP Logged
do you know if it is possible to get a plug with all the required wires to set up the car for a new head unit so that i can use an adaptor plug to connect it to my new head unit?
leading_edge
Member - Posts: 10
Posted: November 29, 2004 at 7:24 AM / IP Logged
the method you posted up is pretty much exactly what i was thinking so i will just do it that way.
bullman96
Silver - Posts: 294
Posted: November 29, 2004 at 7:28 AM / IP Logged
you might be able to find one, but looking at one of those, i would sugest redoing it. it didnt look like they had the stereo in mind when designing it
DYohn
Platinum - Posts: 10,741
Posted: November 29, 2004 at 10:35 AM / IP Logged
The Holden Gemeni TE was (I believe) made for Holden by Isuzu.  I would check with a local Holden dealer or service center for the stereo wiring diagrams, or even in a local library with a gfo0od reference section.  A standard Isuzu harness may fit.  In Australia, the most common wiring harness adapters are made by Aeropro (although their website seems to be down....)
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
