interesting noise problem
jeffchilcott
Platinum - Posts: 2,483
Posted: December 04, 2004 at 6:02 PM / IP Logged
I would put this in ground noise but I am not sure where to head now..Problem started long ago
When I plug both front and rear RCA's into my 4 channel I get a whine, alternator whine... If use a y splitter and run rear or front to both sets of inputs no whine..
I though rca's...Replaced them   Same thing
Though rca location..I have even tried duct taping them to the celing!   still whine
So I though deck, Re grounded the deck to about 4 diffrent spots..each one same amount of whine.
Changed the deck to a new model..same thing
Thought it was the EQ..regrounded..whine...eliminated it out of the system..still whine
Though it was the cheap amp I was using..Bought a diamond audio 600.4    same thing..but slightly better, I mean very very slight
Though maybe battery, fliud full. charge full, battery tested OK
I have regrounded every component in the system and also changed almost all the components
ANY SUGGESTION????????
2007 USACI World Champion
2007 World Record
2006 USACI Finals 2nd Place
jeffchilcott
Posted: December 04, 2004 at 6:05 PM / IP Logged
I just though of it, Maybe I should try regrounding the battery..and alternator????    Just a thought
Also if any SQ guys have any advice on helping noise floor that would be great.   Before I run the car in sq, I think the 2.5 volt output deck I have needs to be replaced, I think that would help my noise floor isues
For those who dont know Noise Floor is.. When you play a blank track on your cd and you can max the volume and hear a hissing or poping noise..I personally have a strong hissing noise
2007 World Record
DYohn
Moderator - Posts: 10,741
Posted: December 04, 2004 at 6:37 PM / IP Logged
I hate to say it Jeff but it sounds to me like you have a head unit with an inferior preamp and that the ground plane on the two outputs (front and rear) are unequal.  So you are hearing the ground loop caused by the differences between the two line-level signals.  This is actually common in cheaper consumer-level heads.  If you have a good multimeter, check for resistance between the ground rings on the preamp outputs, or voltage between the rings during operation.  It should be less than 0.1 ohms and/or less than 1mv.
Voltage output is less important in creating a better noise floor than is a quiet preamp.  Look at the S/N ratings on your head.  World-class performance is in the neighborhood of 100db.
furflier
Copper - Posts: 236
Posted: December 04, 2004 at 8:56 PM / IP Logged
I know this might sound weird but try connecting the grounds on the rca's together. I have done this before on hu's that had this same problem. Beleive it or not it took care of the problem.
jeffchilcott
Posted: December 05, 2004 at 1:24 AM / IP Logged
hmmm I might have to try that.    did you just ground the 2 rca sets FRto RR and FL to RL   or did you connect them like that and also ground the rca's as well??
As far as the deck I know, I should be running a far better deck for the eqipment I have..I am running a panisonic 5310   Actually it is one of the better built in eq's I have used, lets you fully adjust 8 frequencys. I will be starting to look into eclipse and other high end decks, but I love the ease of use that all the panisonic decks have.
Does anyone know of a deck that has a fully adjustable EQ in more then 8 bands built into the deck, and will truly work??
Here is a list of the current equipment
panisonic 5310
power acoustic dvd
2 5.6 inch screens
memphis hc50 sub amp
diamond 600.4 internal
alpine 6.5 type r comps
memphis 5.25 co-ax
eclipse aluminum 10's
2007 World Record
DYohn
Posted: December 05, 2004 at 10:30 AM / IP Logged
You could try connecting the outer rings of front and rear pre-outs together, but be sure to try this with the head OFF!  You run the risk of destroying both preamps... but if your head has that much voltage differnetial between them, perhaps it is time to trash it anyway.  The best logical step up for you would probably be an Eclipse.  Don't be too stuck on replacing the Panasonic EQ (which is good, I agree) because in a properly setup vehicle you really shouldn't need it, but if you like EQs the new Eclipse 5444 might tickle your fancy.
jeffchilcott
Posted: December 05, 2004 at 1:25 PM / IP Logged
i will be sure to check into that, If i wanted a tempory fix would you recomend grounding the front and rear rca's together?   I havent done this, and sounds like trouble to me,   If i hook them up with the head unit off, as soon as I turn it on wont there be problems?
Like I said I really like the ease of use of the panisonic decks and the eq feature as well, But I am more then willing to go to an eclipse deck,   What do you think of the Alpine d300?   do you think will surfice for a good sq deck?
2007 World Record
furflier
Copper - Posts: 236
Posted: December 05, 2004 at 2:13 PM / IP Logged
Yes just connect the ground of both rca's together. Then you can power the hu. There should not be any problems doing this. Like I said I have done this several times without any incidents.
furflier
Copper - Posts: 236
Posted: December 05, 2004 at 2:17 PM / IP Logged
One other thing this is by no means a fix it will just help you isolate the problem. I would not recomend doing it for a long period of time. Not that you did not know this!
jeffchilcott
Posted: December 05, 2004 at 2:58 PM / IP Logged
well I will try it out sometime this week, It is raining today and really dont want to get out and work on it at the house.   Besides its sunday and football is on....Go Lions!
2007 World Record
Monday, September 15, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
