steady beat
norcalcreations
Member - Posts: 18
Posted: December 21, 2004 at 2:26 AM / IP Logged
I just hooked up a new amp and there is a steady beat coming out of the sub.  I remember I have had this problem in the past, but can't remember what I did to fix it. Is it the ground?  I searched the forum but couldn't find anything.  thanks a lot for any help.
If you think you know everything you will learn nothing
Bestbuy577
Member - Posts: 31
Posted: December 30, 2004 at 10:06 AM / IP Logged
Hmm...steady beat....sounds like you have the inputs into the amps outputs that are made for bridging amps together....(second pair of rca)
Best Buy Store#577 Oxford Valley, PA
bigboi11
Copper - Posts: 83
Posted: January 03, 2005 at 8:05 AM / IP Logged
When mine was doing that it was the ground
