amp cutting out, need help
olingerd
Member - Posts: 17
Posted: December 27, 2004 at 5:58 PM / IP Logged
I have a california 300WX1 at 2 ohms going to a a MB Quart DVC 12.  Just bought both of them and I wired the Sub in parralell to be at 2 ohms.  I have a problem with the amp cutting out if I turn it up just past half way.  If I run the amp for like an hour or two it does okay and there is no cutting out.  I have only 4 feet of 4 gauge power cable and 4 feet of ground(4 gauge) and right now the CB I have on it is way to big at 120amps I just need to get a 60amp fuse, but could this be the cause??  I have no Idea what to do??  I have never had this problem before with any of my set ups.  Probably just the cheap amp!!
Teamrf
Gold - Posts: 1,031
Posted: December 27, 2004 at 6:18 PM / IP Logged
If there is not enough current running to the amp it will most likely shut itself down if it has that type of protection on it. Check your ground-make sure it is clean.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
olingerd
Member - Posts: 17
Posted: December 27, 2004 at 6:47 PM / IP Logged
Okay so if I unhook one of the rca inputs to the amp I can turn it up as loud as I want but as soon as I hook back in the other side of the rca the amp cuts out after about half way up???
geepherder
Platinum - Posts: 3,668
Posted: December 27, 2004 at 8:28 PM / IP Logged
It sounds like your gains are set too high.  Try backing them off a bit and see if that helps.
fuseblower
Silver - Posts: 403
Posted: December 28, 2004 at 9:01 AM / IP Logged
Check your gains, sounds like a distortion issue.
uthinkuknoaudio
Silver - Posts: 760
Posted: December 28, 2004 at 9:04 AM / IP Logged
Check your gains, but you might need to get a high output alt. If your going to power the CB and the Amp, you ared drawing a lot of current and you might want to boost it up a bit. When your amp doesn't receive the proper amount of current, it will most likely shut itself down as stated above.
"I don't play games. I play Nakamichi and that for real yo" - Probably some japanese kid said this in the early 80's trying to sell stereo out of his trunk lol.
