1992 BMW 525 radio wiring
itmdtr
Copper - Posts: 131
Posted: January 25, 2005 at 7:51 PM / IP Logged
A friend at work attempted to install an aftermarket radio into his BMW.
He cut the factory plug for the radio off of the harness. He threw it out so I wasn't able to solder it back together. I need to know the wiring colors for power/ground and speakers. He said he hooked it up but the speakers weren't playing. Is there a wire that powers an amp coming from the radio?
I've never put a readio in a BMW, and can't find the wring info.
Thanks in advance. (I hope he didn't burn something up...)
itmdtr
icacha
Member - Posts: 19
Posted: January 30, 2005 at 1:39 AM / IP Logged
RED / green = permanent
purple = accessories
brown = ground
white = auto antenna
some of those if not most had an amplifier in the boot. look behind the left or it could be right as in australia everything seems to be on the other side to the states. there you will find either a becker or blaupunkt amp. the only way i know if the amp isnt working is to run cables from the deck to the speakers, BUT the amp has the crossovers inbuilt and you will have to supply passive crossovers to the speakers.
its the long way if you want to do it yourself or the option to take it into a store is also there. these cars arent the easiest ones to work on so unless you know 100% what your doing its best left to the pros.
Friday, March 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
