Lexus GS300 94
Thack79
Silver - Posts: 526
Posted: February 02, 2005 at 6:49 AM / IP Logged
Anyone have a wire diagram from a 1994 GS300 LExus and know where to find a wire harness and dash kit for it. I attempted to use the factory deck bypassing the factory amp to two aftermarket amps, but I am having some serious issues. Help needed?
Is the Toyota 87 + the right harness for this car?
Bmnicolosi
Copper - Posts: 173
Posted: February 02, 2005 at 10:36 AM / IP Logged
12volts wht/red or blk/red   +  ignition harness
Starter blk/wht or blk/blu   +  ignition harness
Second Starter
Ignition BLACK / YELLOW   +  ignition harness
Second Ignition BLACK/ orange   +  ignition harness
Third Ignition
Accessory pink/blu   +  ignition harness
Second Accessory
Power Lock black   -  passenger kick panel
Power Unlock BLACK / YELLOW   -  passenger kick panel
Lock Motor
Unlock Motor
Parking Lights+ GREEN/ black    at dimmer or dash illu
Parking Lights-
Door Trigger RED / white  -  at fusebox
Dome Supervision
Trunk/Hatch Pin
Hood Pin
Trunk/Hatch Release
Factory Alarm Arm
Factory Alarm Disarm RED / black   -  driver kick panel
Notes: Single (-) pulse will disarm without unlocking. A second pulse will unlock all doors.
Disarm No Unlock
Tachometer black   ac diag plug or igniter
Brake Wire
Horn Trigger green  -  steering column
try your local circuit city, we have a ton of the gs 300 kits at my store, also its prob not the 87 and up toyota harness.  it is prob a harness with 4 rca's that integrates the amp, if i were you i would just bypass the amp all together and just hardwire everything.
Thack79
Silver - Posts: 526
Posted: February 02, 2005 at 11:46 AM / IP Logged
Thanks!... that harness that you are talking about, is it the 70-8112. If so, is this the right harness to use an aftermarket deck and aftermarket amp.
