What size enclosure
Lizardking
Copper - Posts: 184
Posted: February 07, 2005 at 11:13 PM / IP Logged
Guys/Gals
What size enclosure do the Eclipse SW9122 subs require sealed?? I can't find any info on the net about enclosure size..
Eclipse "Approaching Perfection"
stevdart
Platinum - Posts: 5,816
Posted: February 08, 2005 at 9:47 AM / IP Logged
SP_L.pdf ( manual for Titanium series incl. SW9122 )
This manual specifies "small sealed enclosure" but doesn't give exact volume.  However, in this manual are pre-made enclosures designed for use with these woofers.  Looking at the SW6124BX 12" enclosure system, it shows outside dimensions of the enclosure.  Using this site's volume calculator and figuring 3/4" thickness of baffles, the interior volume comes out to 1.3 ft^3.  This is near the same amount of volume that I have seen Rob recommend (1.25 ft^3) for Eclipse 12" subs.
Lizardking
Copper - Posts: 184
Posted: February 08, 2005 at 12:13 PM / IP Logged
Thanks a bunch!! So you think 1.25 cu/ft per sub would be a good start?
