conecting kenwood amp
mishkakasalapiy
Member - Posts: 27
Posted: February 13, 2005 at 1:33 PM / IP Logged
i conected a kenwood amp and for somre reason the light doesnt come on does anybody knowwhat might be wrong?
need help thanks
DYohn
Platinum - Posts: 10,741
Posted: February 13, 2005 at 1:36 PM / IP Logged
You "connected" it how and to what?  Where is the power, ground and signal coming from and how is it fused, etc?  What speakers are connected to the amp?  Is the amp new or used?
mishkakasalapiy
Member - Posts: 27
Posted: February 13, 2005 at 1:41 PM / IP Logged
ok I am connecting front kenwood component speakers and rear infinity speakers to a 4 channel amp. Everything seems to be connected fine but the amp wont even turn on. I didnt actually connect all 4 speakers yet but just connected one fron speaker to an amp and crossover just to test it. Amp is brand new, and I bought 4 gauge amp kit and RCA cables and speaker wires. I used the inside of the car trunk as a ground connnection. Thanks
tcss
Silver - Posts: 1,623
Posted: February 13, 2005 at 1:46 PM / IP Logged
Is the remote turn on lead hooked up?
mishkakasalapiy
Member - Posts: 27
http://www.crutchfield.com/S-gKDTnPT3OlI/cgi-bin/ProdView.asp?g=120&id=learn_about&i=113KAC8401
http://www.crutchfield.com/S-GBTI5jiR6qP/cgi-bin/prodview.asp?i=1086925I (rear speakers)
http://www.crutchfield.com/S-GBTI5jiR6qP/cgi-bin/ProdView.asp?g=76300&I=113KFCXR51 (front speakers)
mishkakasalapiy
Member - Posts: 27
Posted: February 13, 2005 at 1:50 PM / IP Logged
I am no sure on what you mean by that
tcss
Posted: February 13, 2005 at 1:58 PM / IP Logged
Between the power and ground is a terminal that should read Rem. This needs to be connected to the Blue/white stripe lead on your head unit. When the head unit is turned on it shoots 12 volts to this lead and turns the amp on.
rickfordfosgate
Posted: February 13, 2005 at 9:33 PM / IP Logged
maybe your connection is ok but the connection didnt work properly... i meant amp have 3 terminal, power dc 12v, acc-rem and ground. be sure that the direct current from terminal positive is working that is can supply current... after that you can connect the remote terminal direct to the power terminal. this is to make sure that the amp is working with the yellow light led for the indicator. if your amp working properly, i meant the led is turn on... you can connect the rca cable from the head unit to amo and connect the speaker cable to speaker. check the amp, if the led turn to red color... maybe your amp is protected. in this matter your speaker are broken. try other speaker. but if the amp is ok with the yellow light.... maybe your connection from head unit to amp input are not working properly... try to plug in and plug out the rca cable from head unit to amp when the amp is on. try to use the hi to low connector.
rick engineering
